Old 05-05-2016, 07:34 AM   #1
2016 30' Flying Cloud
Oviedo , Florida
How to remove Clarion speaker grills?
I'm going to install Polk DB651 speakers and need to know how to remove the grills from the stock Clarion speakers. This is a 2016 FC
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
khollister is offline   Reply With Quote
Old 05-05-2016, 11:34 AM   #2
richw46's Avatar
Lexington , Kentucky
Your best bet would be to call the dealership or the Airstream customer service line and ask them. (877) 596-6505.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 05-05-2016, 03:10 PM   #3
Oviedo , Florida
I'm at JC so I asked a tech - he said they twist off. Doesn't work. So if someone has had them off on a 2015 or 2016, please pass along the secret.
Keith & Barb
Old 05-05-2016, 09:34 PM   #4
TCwheels's Avatar
2011 20' Flying Cloud
Traverse City , Michigan
This would be helpful to know....
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 05-06-2016, 11:22 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Some speaker grills are attached with the same screws that hold the speaker in place.
Sometimes you have to remove the actual grill from the surrounding trim to gain access to the screws.
Sometimes it is simply a compression fit or has some type of sticky goo material to hold it in place.
I agree that Polk Audio are good speakers at a reasonable price point as I have a pair of Polk tweeters in my 1999 Nissan Pathfinder, but I would think the Clarion speakers are also of a decent quality.
Why the change?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-06-2016, 11:30 AM   #6
2012 25' FB Flying Cloud
Parker , Colorado
Pardon my French, but the Clarion speakers suck. Night and day between them and the Polk Audios, I have some in my car. But I have an extra set of Bose AM5's at home, and was wondering if anyone has found a way to hook up 110 volt speakers to a car audio system which is what we have in our trailers. Some kind of a converter? I'd like to replace the Clarions with the cube Bose since I already have them.
2012 25FB with solar
2012 Toyota Tundra 5.7L V8
mfrez is offline   Reply With Quote
Old 05-06-2016, 11:57 AM   #7
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
The Polks are so much better than the stock Clarions. I replaced mine, in the trailer, last year. The sound is clearer, not tinny, better for music and voice. In fact they are so much better, I can actually hear the TV sound through them with the AC running. On my 2012 the grille is screwed the cabinet and the speaker just is press fit into the top of the grill. After I removed the grill, it was clear that the Polks would not fit into the grill so I had to use the one that came with the Polks. That required new holes in the cabinet, of course.
Larry
lsbrodsky is offline   Reply With Quote
Old 05-06-2016, 01:00 PM   #8
2012 30' International
Livingston , Texas
Speaker Grill Problem
I have the opposite problem. On almost every trip, one of my speaker grills falls off, not competently, it will hang by a thread. I just keep pushing it up in it;s place and start all over again in the next trip. Being the rear bedroom speaker, I'm guessing the back of the trailer does a lot of jumping up and down because we can't keep clothes hangers on the closets, either.
glenrms is offline   Reply With Quote
Old 05-06-2016, 01:26 PM   #9
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
Centramatics, maybe?
Mike
Caffeinated is offline   Reply With Quote
Old 05-06-2016, 01:56 PM   #10
m.hony's Avatar
2013 30' Classic
Using your Bose speakers shouldn't be a problem at all.
Is the input RCA cables?
If so, RCA cables out of the car stereo to RCA in on the Bose speaker with the amp in it.
Then plug the Bose speaker with the amp in it to a 110 receptacle.
TAC #MS-10
Airforums #70955
Old 05-07-2016, 11:42 AM   #11
Parker , Colorado
The Bose subwoofer doesn't have it's own amplifier, or 110 power cord, it relies on the sound amp. Needs minimum 10 watts per channel 4 or 8 ohms. Somebody correct me if I'm wrong, but I don't think the standard Sony deck has enough power.
Old 05-08-2016, 09:43 AM   #12
m.hony's Avatar
2013 30' Classic
The Sony's internal amplifier should be 4 channel 50 watts per channel.
TAC #MS-10
Airforums #70955
Old 05-08-2016, 10:09 AM   #13
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Polk Audio
The grill on the Clarion speakers does sort of twist off, but one has to know which way to twist, and they are tough to get a good grip on. Once removed, before the Polk's are installed in the aluminum areas, it is a good idea to glue closed cell foam around the opening between the outer and inner skins, thus damping the potential resonance, and making the mounting surface for the new speakers much stiffer, improving response.
My example:
Bose speakers replacing Clarion by Tommie Lauer, on Flickr
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 05-08-2016, 10:28 AM   #14
TCwheels's Avatar
Thanks Tommie! Very helpful!
2015 International / Clarion / Samsung Questions cbrittan Audio, Video & TV 15 03-07-2016 09:24 AM
FREE: Clarion M502 and 2 speakers Gsmblue Audio, Video & TV 6 05-22-2015 12:05 AM
Binning the Clarion M502 Gsmblue Audio, Video & TV 9 04-07-2015 01:04 AM
Clarion, Pa. Autumn Leaf Festival 2014 pintoman Other Rallies & Events 1 09-13-2014 09:04 AM
Speaker Switch & Speaker Replacement vswingfield Audio, Video & TV 17 10-01-2011 06:48 PM
