Old 04-07-2007, 03:21 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
How to remove 8-track?
The original 8-track has stopped working, radio is fine. In trying to remove, it appears the whole case is riveted down. Is it possible to slide the player out of the case as opposed to having to remove the pedestal it sits on as well?
Is the case a standard size where a CD player would slide into it?
Dan
Name:	8 trac 002.jpg
Dan S is offline   Reply With Quote
Old 04-07-2007, 03:42 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Nothing's ever easy
Looks like you will have to remove the nuts holding the mount in the cabinet, and then remove the player from the mount. Once you get it out, it should be an easy task to install a new CD (or cassette) player in its place.
Old 04-07-2007, 05:06 PM   #3
Dan S's Avatar
1975 Argosy 26
Nut & Rivrets
The nuts on the inside that you are seeing on the bottom of the cabinet are rivets from underneath. I don't have a rivet gun.....is it as easy as going to Home Depot and picking one up? I assume you have to drill out the old ones from underneath?
Dan
Old 04-07-2007, 07:33 PM   #4
till's Avatar
Lisle , Illinois
Images: 108
And here I thought that you could just use a little dynamite. But I see you wish to keep the trailer.
"The operation was a complete sucess, but the paitent died.."
Sorry , I could not resist.....
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 04-07-2007, 09:07 PM   #5
Marti's Avatar
Images: 20
If you want another 8 track player... you may find one of those oldies but goodies on ebay... worth a try...
Marti is offline   Reply With Quote
Old 04-07-2007, 11:36 PM   #6
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Dan
They are available for not too much $$. Under $20 for a "decent" one IIRC.
Yes, you'll have to drill out the old rivets. It's all really pretty simple if you can access the rivets.
Dave
Fyrzowt is offline   Reply With Quote
Old 04-08-2007, 06:25 AM   #7
Well Preserved
1993 21' Sovereign
I got a swivel-head rivet gun, they are available from Sears for about $10 more than the fixed head ones. The swivel can be very useful, if not in this case, it will at some point in the life of your trailer. BTW, be sure to use aluminum rivets when you put it back together.
Old 04-08-2007, 04:39 PM   #8
Dan S's Avatar
1975 Argosy 26
picked up a rivet gun
I just picked up the swivel one at Sears for $17.95 and a few assorted aluminum rivets. It's not entirely clear as how these work....any tips?
Dan
Old 04-08-2007, 05:29 PM   #9
Well Preserved
1993 21' Sovereign
Dan
The tips on the rivet gun are made to fit the nail looking part of the rivet. It should slide in snugly. When you put a new rivet in, slide the nail part into the rivet gun, and push the works into the hole you have drilled. Make sure the flat (head) of the rivet is flush against the surface you are trying to rivet. Pump the handle until the nail part pops out. You can then go on to the next rivet. The nail part will only slide into the rivet gun when the handle is released. Hope this isn't too much a simplification.
Old 04-08-2007, 09:05 PM   #10
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Here is a good "How to" page...
Pop Riveting, Using A Pop Rivet Gun
Richard
Old 04-08-2007, 09:55 PM   #11
Dan S's Avatar
1975 Argosy 26
Thanks Richard, a picture is worth a thousand words.
Old 04-09-2007, 12:00 AM   #12
Fyrzowt's Avatar
2000 25' Safari
Images: 8
If you feel the need, practice on a scrap piece of metal. You'll then have a visual of what is actually happening when you "pop" the rivet.
Dave
Want to remove antenna. Happycampers Audio, Video & TV 7 04-20-2004 07:00 PM
Stone Guard/ Keep it or Remove it? 74Tradewind Rock Guards, Segment & Window Protectors 9 06-26-2002 01:09 PM
How to remove the glass from windows? Andy R Windows & Screens 2 06-19-2002 09:30 AM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
inside light lens' how to remove to clean Paul Daugherty Mechanics Corner - Engines, Transmission & More... 12 04-25-2002 10:51 PM
