Old 04-04-2010, 01:36 AM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
How to Remove 70s Radio Assembly
I didn't see anything that specifically details how to remove this assembly on this forum. Does anybody have any pointers and tips? Bought a new SONY radio and I need to get the old radio/8-track out.
Here's a pic of what I'm talking about:
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 04-04-2010, 03:38 AM   #2
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
If you have a Control Panel above the stereo, pull that out and then look down through that hole and you'll see a couple of screws coming in from above into the frame around the stereo. I think there are also a couple on the sides which you can see already in the cabinet. There'll be a mess of wires back there to match up with your new stereo. Good luck!
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 04-04-2010, 08:01 AM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks Dallas.
So does the whole thing come out or just the shelf that the radio sits on?
I looked for some screws on top from the control panel hole but didn't see any. I did see four rivets on the back wall underneath the shelf but the space is too narrow to fit a drill in there to drill them out. I also see some rivets holding the bottom of the assembly to the main unit. Do I need to drill those out too?
1958 Overlander
4CU 1st VP
Old 04-04-2010, 08:11 AM   #4
DPeakMD's Avatar
1975 23' Safari
Franklin , Indiana
It's been a few years since I worked on one, so forgive me. I also think mine had been removed by a prior owner who replaced rivets with screws. So yours may vary. I definitely remember there were screws from on top b/c I took every other screw out that I could see and it held fast until I discovered those. It was more by feel than anything else because it was impossible to look into the hole and straight down and back towards the front of the radio frame. When I took out those two screws the hole she-bang came out rather quickly into my not too prepared arms!
I would start drilling rivets and see what comes loose. Could you use one of those drill flex extensions to get to those rivets? I remember that the frame came out with the radio attached to it.
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
Old 04-04-2010, 08:26 AM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks Dallas. When you say "frame" are you talking about the shelf the radio sits on and the two sides?
Drill flex extension? Never used one. I assume I can get one of these at the big box stores, correct?
1958 Overlander
4CU 1st VP
Old 04-04-2010, 09:48 AM   #6
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Here are several choices . Amazon.com: flexible drill extension US Home Improvement They can be found at any hardware supply.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 04-04-2010, 01:13 PM   #7
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Neil.
Thanks FreshAir, you learn something new everyday.
1958 Overlander
4CU 1st VP
Old 04-04-2010, 02:56 PM   #8
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Okay, I got this unit out today. I forgot I had a smaller electric drill.
For the benefit of those who may need this info in the future, here's how you remove the radio assembly. There are four rivets on top and four rivets underneath at the back. I took a putty knife and cut the rivets to the top and drilled out the rivets underneath. That's it! Once those eight rivets are removed the unit will fall out. Note that the sides do not remove, just the shelf assembly.
Has anybody reused the shelf assembly with a newer radio? Trying to decide how to mount the new radio where the old radio used to be.
1958 Overlander
4CU 1st VP
Old 04-17-2010, 12:07 AM   #9
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Got this project done yesterday. I used the old shelf unit and mounted the new CD Radio in it. I also wired a switch to eliminate phantom battery drains while Boondocking. For my IPOD I also wired a 12v power point.
The pics show the shelf unit with the 8-track, radio, and the face plate removed and the final installation.
ID:	100457   Click image for larger version
1958 Overlander
4CU 1st VP
Old 04-17-2010, 12:20 AM   #10
JFScheck's Avatar
Rockville , Maryland
Images: 33
Great Work - was the old system transistors or tubes?
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-17-2010, 07:24 AM   #11
DPeakMD's Avatar
1975 23' Safari
Franklin , Indiana
Looking good Mike!
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
Radio Speakers but no Radio 1969 ???? tdoescher 1965-1969 Sovereign 13 04-21-2015 02:17 PM
cb radio, cassette radio jagcb750 Classic Motorhomes 14 04-19-2012 03:32 PM
70s Wallpaper Paste BrockLives Upholstery, Blinds, Walls & Interior Finishes 1 08-28-2009 09:15 AM
Parts--70s Soverign Zeppelinium Ribs, Skins & Rivets 2 03-20-2006 06:35 PM
Mid 70s Argosy Silvertwinkie All Argosy Trailers 10 04-22-2005 06:13 PM
