Old 09-04-2016, 12:58 PM   #15
2007 22' International CCD
Originally Posted by MelGoddard View Post
."Last year I couldn't spell 'ENGG-IN-…AR" , now I are one"!
I have the coffee cup....
As well as the tee shirt with the definition of the engineer, "A person that takes a concept, and produces malfunctions.." Or words to that effect.
If you can't laugh at yourself, you are in bad shape.
KE4GNK/AE
Old 09-04-2016, 07:16 PM   #16
StreaminGeo's Avatar
2004 25' Safari
Hanford , California
The local Walmart (Superstore!) didnít have anything approaching the small size we want for a screen. I looked online at some models. Can anyone recommend a good set with a 12-inch (or so) screen? One with a DVD feature would be good.
Upon further trailer examination, Mr. Thorough discovered this additional jack fixture in the bed area, presumably for a TV there as well.
And, hereís also a shot of my antenna. Looks like Iíll have to get the extra bit to get UHF, but I can experiment with this for a while?
Name:	Bedroom Switch.JPG
ID:	270825   Click image for larger version
StreaminGeo is offline   Reply With Quote
Old 09-04-2016, 07:55 PM   #17
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Originally Posted by StreaminGeo View Post
The local Walmart (Superstore!) didn’t have anything approaching the small size we want for a screen. I looked online at some models. Can anyone recommend a good set with a 12-inch (or so) screen? One with a DVD feature would be good.
And, here’s also a shot of my antenna. Looks like I’ll have to get the extra bit to get UHF, but I can experiment with this for a while?
Depending on the distance from the transmitters you may find it works fine. I am 70 miles from the transmitters serving the Orlando area and I got them fine before I got the Wingman. When I added it the signals were stronger in that the pointing was less critical, and I got signals from the West Palm area, around 100 miles away, but not consistently.
Al
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-04-2016, 08:15 PM   #18
cameront120's Avatar
1972 25' Tradewind
You could always forget the TV and just stream shows on an iPad.
North Vancouver, BC
Old 09-04-2016, 08:15 PM   #19
2004 22' Safari
That is the same as mine and it picked up digital channels as long as you are in line of sight of some transmission towers. Added the Wing Bat attachment to it improved the number of channels I can pick up. Adding the Wing Bat took less than 3 min. to do. Very easy.
I think you will have a real tough time finding a 12" TV. Most consider the 19" to be on the small side and it does fit perfectly in my 22' does not appear to be that large due to the flat screen.
Northerngirl is offline   Reply With Quote
Old 09-05-2016, 10:58 AM   #20
1979 23' Safari
Wayland , New York
Cool, I haven't had to deal with an old antenna so wasn't sure how it would do picking up digital signal. Wasn't sure if they shifted to a different frequency spectrum when the transition occurred. Makes it easier. Sounds like you just need a tv. Can't help with a 12" though. That's pretty small and probably tough to find. I'm having a hard enough time finding a good 19-22".
Old 09-06-2016, 11:28 PM   #21
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
12 v. TV's are much more expensive than 120 v. ones. They claim the ones made for RV's can take the shock of travel better, but our cheap TV in the bedroom has survived quite well; the OEM TV has too and I doubt it was made for RV's since it is a 120 v. model. If you need TV when boondocking, you can use an inverter to watch a 120 v. TV, but batteries can be run down if you are running the furnace and a lot of incandescent lights. We have a small 120 v. cheap TV in the bedroom plus a separate inverter, but we have used it infrequently.
If you want a TV with a DVD player, remember when one stops working, you need to replace the whole thing. Our trailer has a 12 v. radio/DVD player that connects to the main TV, but when boondocking, we survive quite well with CD's or radio or reading.
Gene
Great deal but No Title, Should I get it? How to get title in MI or NY? Gypset Title, VIN & Registration 13 03-28-2017 06:15 PM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 10:48 AM
Question re how to cut aluminum sheeting and get a clean edge... williamhenshall Ribs, Skins & Rivets 7 06-12-2002 06:58 PM
Where to get new cushions made? Andy R Upholstery, Blinds, Walls & Interior Finishes 8 04-16-2002 02:32 PM
How do I get to my pictures? Rik Forum Admin, News and Member Account Info 1 03-02-2002 12:32 AM
