Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 06-11-2006, 08:33 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
How do I hook up to the antenna?
I know this sounds like a dumb question, but how do I hook up to my '76 excella antenna? It has a 12 volt outlet and a screw a hole. Do I need to change out the whole thing to work for a LCD tv? The tv only has cable type ports for all input/output options. The antenna goes up & down perfectly, so I want to use it! Thanks,
Becky
Becky B. is offline   Reply With Quote
Old 06-11-2006, 09:32 PM   #2
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
If I understand your question correctly, you may need a 300/75 ohm matching transformer:
http://www.skyvision.com/store/mi3000016.html
SilverRanger is offline   Reply With Quote
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
Antenna connection PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 10-10-2002 03:15 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
