| Help with television removal
Lucy is a 2005 25FB with the factory installed 15" Sharp television with the external AC adapter/transformer box. I am in the process of installing a new 19" digital television that is AC-direct powered and does not have an external adapter/transformer box.
My problem is getting the transformer box out of the wall. There are only two 1" holes for the wires to come out. Apparently, this installation was completed before the refrigerator was installed.
As I see it, my options are:
1. Remove the refrigerator to access the back side of the wall.
2. Remove the wall panel next to the couch.
3. Cut an access hole in the wall.
I am leaning toward #3 as I can cover the hole with the television mounting plate. If I do#1 or #2, I will have to do the same thing again when I replace this television. If the hole ends up too big for the mounting plate, I figure that I can cover the area with a thin piece of wood.
Are there any thoughts out there on this? Maybe someone has a different way to go. I'm open to suggestions.
I've included a photo of the area that I'm talking about.
Thanx, Brian
__________________ SuEllyn & Brian McCabe WBCCI #3628 --- AIR #14872 2005 25' Safari FB (Lucy) with HAHA 2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy) |
