Old 02-21-2008, 06:05 PM   #1
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Help from an audio junkie
Hello everyone, I have installed a new 12V. system. My question is my amp for my new audio system at full power produces 44 amps. it will never see this although my new parallax is a 55 amp. If it matters the battery is a 27 series lifeline. Do I have a problem here. Thanks Robert
bertro is offline   Reply With Quote
Old 02-21-2008, 06:15 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Your neighbors might, if you crank it up...
Seriously, it is close to the capacity of the converter, and if used at full output, along with some lights and charging the battery, it may exceed the capacity of the converter. When you turn it off, though, it should recover the battery if the capacity is exceeded. I would be more concerned with the trailer wiring, most of the circuits are only 20 amp or so capacity, unless you are running fresh, higher-capacity wires direct to the amp, and properly rated wires from the converter to the battery.
Old 02-21-2008, 06:41 PM   #3
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Yes all wireing will be new and correct size. Also no holes cut for speakers just a coulple of corner boxes and front boxes built. I love good sound and I'm selling an old mercury I had it in and wanted to put it to good use. Thanks for the reply. Robert
Old 02-21-2008, 08:17 PM   #4
Area 63 Productions
1958 22' Flying Cloud
1963 19' Globetrotter
Orange , California
Send a message via Skype™ to Area63
Your battery will act as a current buffer, and supply plenty of power to the amplifier.
The converter will merely recharge the battery, for the most part, even though it is all parallel.
The capacity of current from a battery is enormous. You would be hard pressed to exhaust it with a car audio amp, unless you're talking competition systems.
The amp might draw 44amps at full power, over the full frequency range, but that rarely happens.
I doubt that it will draw more than 10 amps at annoyingly loud volume, with peaks perhaps reaching the 44amp limit.
In any case, I do not believe that you have anything to worry about.
Area63 is offline   Reply With Quote
Adventures in Audio / Video R&SZinser Audio, Video & TV 11 08-13-2007 07:32 AM
add XM to audio-video pkg? starflyte1 Computers, Internet & Satellite 12 06-02-2007 01:47 PM
AS speaker audio from LCD wheel interested Audio, Video & TV 22 06-10-2006 06:46 AM
Safari Audio/Video Options TheLuvShack 2005 Safari 3 11-10-2004 05:02 PM
Repairing The Audio System Rodger with a D Audio, Video & TV 1 07-20-2004 10:11 AM
