Originally Posted by ghaynes755
I've had mine off for months during the winter. Call them to reactivate and when I get to the first camping spot everything has worked fine. Are you deactivating between trips? If so then you do need to re-activate on next use. Since DISH is on monthly billing if you ask to deactivate mid month it doesn't actually seem to happen until the start of the following month.
While Dish is monthly billing, they do prorate the charge on a daily basis. Any over bill based on a monthly statement cycle is credited back the following month.
I really decided to start carrying a Tailgater and 211z a couple of years after digital broadcasting started. We found that in many cases signal levels went down and where we had service with the batwing antenna on the Airstream, all we now got were signals popping in and out. Many of the campground owners noted that they had to raise their home antennas to keep their own service. Since I already had satellite TV at home, it was pretty nice to have the same level of service on the road. The only bump in the road is having a clear shot at the satellites, and there are some great iOS apps out there that allow you to look at the sky with your phone to determine where to set the Tailgater unit.
