Old 04-23-2009, 04:50 PM   #1
Santa Fe , New Mexico
HDMI cable for 20' Flying Cloud
I bought a 2006 Safari SE and supplied my own HDMI cable to connect my satellite receiver placed on the dinette table to the TV. This was easy to do because the cable could be placed under convenient seat cushions between the mounted TV and the satellite receiver on the dinette table. Now, I'm advising a relative interested in a 20' Flying Cloud.
It appears the TV on a 20' Flying Cloud is mounted above the 'fridge on the right side of the trailer, while the dinette table is on the left side of the trailer. I'm guess the incoming satellite coax comes to a box in this area. So the question is: How do you get a HD signal from the satellite box sitting on the dinette table to the HDTV mounted on the other side of the trailer? Has Airstream been smart enough to string an HDMI cable during the assembly process? When I pressed them on this when my 2006 trailer was being made, the Airstream people (not the dealer, the factory people) didn't know what a HDMI cable was and didn't want to know what one was. So I'm wondering if Airstream is selling trailers that have HD televisions that can't produce a HD image on the TV.
Anybody have some comments?
mistermcfrug is offline   Reply With Quote
Old 04-23-2009, 06:58 PM   #2
Images: 59
Why can't the HD television that came with the trailer use the coax cable that came with the trailer?
markdoane is online now   Reply With Quote
Old 04-23-2009, 07:14 PM   #3
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Then it would not be HD BUT if you could run the coax closer to tv and hook the Satalite up close to the tv you could run the MDMI cable from Sat reciever to the TV. In general the closer the reciever is to the HD tv the better.
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 04-23-2009, 07:24 PM   #4
coax cable doesn't work
A coax cable cannot carry a HDMI signal. Also, those RCA plugs (the yellow for video and red and while for audio) cannot carry a HD signal either. Airstream didn't seem to understand or care about this three years as I mentioned. It just seems odd to me that a so-called high end trailer maker would install a HD television in a trailer that wasn't properly wired.
I'm hoping a knowledgeable owner a 20' Flying Cloud will comment here and confirm that A/S has or has not run a HDMI pre-wire from the dinette area to the TV. Do you know that the cable would only cost about $15 retail? And the labor cost would be about $5 if performed during the manufacturing process.
Old 04-23-2009, 08:13 PM   #5
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
If coax cable won't carry HD signals, you had better not tell all the tv cable companies, including the one that supplies the HD signal to our apartment though a coax cable.
As far as an HDMI cable only costing $15 retail, I just went to Bestbuy.com, and the cheapest HDMI cable retails at $30, and that is for a 3' cable. I think you will need more than 3', so I looked at the next longest cable, which is 6'. It retails for $40. If you need 8', it retails at $100.
I won't even go there as far as how much it would cost the factory to run the cable, but if it takes the person running the cable more than 8 minutes to run it, it won't cost $5 labor.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 04-23-2009, 08:45 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I can vouch for this company, and it is much less expensive (Need Cookies Enabled [their bad, not mine]). HDMI cables are in the "early adopter" phase and are not priced in accordance with any relationship to cost, merely the chance to reap profits. As the product life-cycle moves along the curve, the price of the cables will come more inline with other cables. Meanwhile Markertek is a good source of AV equipment.
I even bought a 1.8 GHz possessor for my old G4 Mac there. I am very pleased.
Vaughan
Old 04-23-2009, 09:11 PM   #7
flint , Michigan
Here's the best site for hdmi cables. I just upgraded to a plasma and recabled everything. Don't pay those ridiculous prices BB wants for cables.
HDMI Cable, Home Theater Accessories, HDMI Products, Cables, Adapters, Video/Audio Switch, Networking, USB, Firewire, Printer Toner, and more!
flashbackk is offline   Reply With Quote
Old 04-23-2009, 10:17 PM   #8
mickeymoose's Avatar
1974 25' Tradewind
Gillette , Wyoming
I second that motion
I agree with flashbackk, monoprice.com has great cable prices. I have used many of them on installs. Another vendor I have used is bluejeanscable.com You should be to find any cable or flat panel wall mount you need at those two places. You can even get the cables in different colors for no extra price.
Cassidy
"Listen, do you smell something?" - Dr. Ray Stantz
mickeymoose is offline   Reply With Quote
Old 04-24-2009, 02:00 AM   #9
1977 31' Sovereign
Images: 33
Ok as far as the coax cable having HD signal from sat disk to sat reciever no but a HD signal from sat reciever to the TV yes it will. Ok and why can't you move sat reciever closer to the TV ? you would need a 15 to 20 foot HDMI cable to from the reciever to the table and that is expensive unless the table is like 5 to 10 feet away and I am totally off .
K/N Cool intake air
Duel power exhaust
Old 04-24-2009, 07:42 AM   #10
Correction
I should clarify my last comment: Coax cannot carry a HD signal from the satellite receiver to the TV. Yes, it can carry signals from the dish itself to the satellite receiver. All my previous comments very clearly were discussing what the heck happens AFTER the HD signal is in the satellite receiver. So we don't need to worry about telling the cable TV company anything.
Old 04-24-2009, 11:54 AM   #11
SaabLover's Avatar
Almost Always Sunny Sarasota , Florida
Images: 12
Coaxial cable can carry HDTV. RG 6 is the preferred size it has a much larger center conductor so it carries the signal better with less drop or if are running any new coax. But if you have RG 59 already and it seems like you are getting a good enough signal it may not be worth trying to run a new one if the run is short. (under 50 feet) With a straight run from the dish to the receiver if possible is best. Each break will cause some drop in signal. If you do have to make a break use the professional type of crimper's for the connectors those twist on connectors are just bad bad bad.
From the receiver box an HDMI cable should be used to carry it to the TV if you want HD. So you will only need to move the box closer. There should be no need for any 20' HDMI cable. I love monoprice.com.
If you have a DVR you may need to run a second coax for the second tuner as DVRs have two tuners.
And I hope that this has made it Highly & Diffidently clear.
SL
1999 Chevy Suburban 7.4LT "Tugger" Last of the big boys! Still going strong. 1992 Saab 900s Convertible 60K miles Not my TV
Almost always sunny here unless there is a hurricane bearing down on you. And then it's time to hook up the burb and roll. So far I've been very lucky.
SaabLover is offline   Reply With Quote
Old 04-25-2009, 12:17 AM   #12
Please focus on issue at hand
I'm afraid I'm not getting much help here. We've established that you need an HDMI cable to go from the satellite receiver to the TV. However, readers seem to be glossing over the key consideration I posed at the outset: on a 20' Flying Cloud the TV is mounted over the fridge on the right side of the trailer while the incoming cable from the satellite dish goes to a box (I believe!) that is located along the LEFT side of the trailer, under the dinette table. So you just can't say "move the satellite receiver closer to the TV." I'm asking if A/S now runs HDMI cables or would run an HDMI cable if asked during the trailer assembly process or if they is any realistic way to carry a HD signal from the satellite receiver on the LEFT side of the trailer to the RIGHT side. I'd appreciate any thoughtful comments.
Old 04-25-2009, 09:29 AM   #13
sd90mac's Avatar
Originally Posted by mistermcfrug View Post
I'm afraid I'm not getting much help here. I'm asking if A/S now runs HDMI cables or would run an HDMI cable if asked during the trailer assembly process or if they is any realistic way to carry a HD signal from the satellite receiver on the LEFT side of the trailer to the RIGHT side. I'd appreciate any thoughtful comments.
I'm definately no expert, but if it were me, I would call airstream and ask them.
I do know airstream will make any reasonable change during the build, for a fee.
good luck
Marie
When people lie to you, and refuse to honor their word, don't regret trying to follow a dream, new adventures and friends await you.
sd90mac is offline   Reply With Quote
Old 04-25-2009, 10:51 AM   #14
Images: 59
Why don't you put in a wireless HDMI system. Then you can watch your HDTV anywhere in the trailer. Or outside on the picnic bench.
help with a '62 Flying Cloud stevenormand 1960 - 1963 Flying Cloud 2 08-18-2018 11:58 AM
19' Bambi vs. 20' Flying Cloud (2008-09 models) metilling65 Trailer Values 23 04-27-2009 10:12 AM
55 flying cloud, how much? Lychgate Trailer Values 5 07-11-2007 05:14 PM
'58 Flying Cloud camperski 1956 - 1959 Flying Cloud 2 05-09-2007 08:04 PM
Looking at a Flying Cloud dmaiden Buyer Guidelines 5 09-26-2006 04:18 PM
