Old 04-04-2011, 10:24 PM   #1
2006 19' International CCD
Amelia , Ohio
Hard To Replace Sony In '06 Bambi?
I'd like to replace the Factory? Sony am/fm/cd unit in our '06 Bambi Int'l CCD. Can anyone tell me how to access the innards to replace the mounting bracket so I can install a new unit...
Tom
jambie is offline   Reply With Quote
Old 04-04-2011, 10:38 PM   #2
tpi
Trabuco Canyon , California
I don't know if you want another Sony or not.
But on mine, the CD player went belly up after a year or two. I bought another Sony at the time and it just slid into the existing bracket. The new one had a front aux input which is nice.
Don't know if the 2011s still use the same bracket. I replaced mine in '07ish.
Don't know the specifics of your trailer but on mine there is an access panel in the cabinet I can remove to get to the back of the Sony car stereo. But I didn't need to by using existing bracket.
Edit mine takes the tool also mentioned in the post below.
tpi is offline   Reply With Quote
Old 04-04-2011, 10:42 PM   #3
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Ours came with special tool to remove unit from bracket. Looks like a special gizmo wrench. Do you have the tool? If not I bet the guys a Best Buy or such can advise you..
mhilley is offline   Reply With Quote
Old 04-05-2011, 05:00 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Yup, slide the tools (there should be a pair) into slots/holes on each side of the radio, push them in, and slide the old radio out.
Old 04-05-2011, 05:25 AM   #5
blmitch5's Avatar
Olathe , Kansas
I went with a Kenwood with Bluetooth. I love it! It also had audio hook ups for surround sound. I took off the side panel in the over head cabinet (3 screws and a good suction cup) to access the wires and drilled a hole for iPhone connection for charging.
While I had the panel off I covered the green with white shelf paper. I hated the green glow. The lower sections are covered with a red mat. I'll see if I have better pictures somewhere.
ID:	126167   Click image for larger version
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 04-05-2011, 05:27 AM   #6
Well Preserved
1993 21' Sovereign
Did you get one that is also a DVD player? They don't cost much more than a regular CD player these days, and give the option of playing movies with one less peice of equipment than was needed with just the CD player alone.
Old 04-05-2011, 05:39 AM   #7
blmitch5's Avatar
Olathe , Kansas
I have a 19' Bambi Our new HDTV had a DVD (won it in a raffle) player in it and we didn't have the av upgrade so we fished for the av cables (above the outlets by the bed) and followed them to behind the tv area and hold your breath, cut a hole and installed an outlet in the bookcase behind the tv. Now we have surround sound!
WBCCI 4973
Old 04-05-2011, 05:56 AM   #8
blmitch5's Avatar
Olathe , Kansas
Here are some pics.
ID:	126169   Click image for larger version
WBCCI 4973
Old 04-05-2011, 07:52 AM   #9
Amelia , Ohio
Hey, thanks for all the replies. I can't find the release tools, so I'll have to consult the mobile audio engineers at Best Buy
If I access the unit from the storage compartment, would I be able to remove the whole unit, mounting bracket and all, without having the release tools? I figure if I'm gonna replace the whole thing anyway, why worry about removing the unit from the mounting bracket...
Cheers,
Tom
Old 04-05-2011, 08:02 AM   #10
CanoeStream's Avatar
St. Cloud , Minnesota
The two release tools are stamped sheet metal -- looks kinda like a car door jimmy. Light gray IIRC. About 3/8" x 6" working just from memory.
I've been looking for a reason to replace mine. It's got a terrible interface with non-Sony products; eg iPods. Does Sony even make an mp3 player? Fail... Putting the morning toast into the CD slot isn't destroying it yet. Will have to try finishing nails. Looks like I'll have to follow up with blmitch5.
5 meter Langford Nahanni
Old 04-05-2011, 09:47 AM   #11
2004 19' International CCD
Los Angeles , California
OP you could use a car stereo install tool kit. Its a bunch of plastic paddles and a couple of stamped metal tools. They cost $5-20 and are great for automotive interior repairs as well (helps in taking the panels apart, replacing interior lights, etc). I used one of the plastic tools to help me open the halogen puck lights on the 'stream...
...While I had the panel off I covered the green with white shelf paper. I hated the green glow. The lower sections are covered with a red mat. I'll see if I have better pictures somewhere.
Hated the orange glow in ours. Yours look great! I took them apart and covered them in aluminum wrap. It looks really slick. I have access to waterjets and plasma cutters and am considering custom cutting aluminum to fit. /off topic
SoCalStreamr is offline   Reply With Quote
Old 04-05-2011, 10:09 AM   #12
aftermath's Avatar
Spokane , Washington
iPod
CanoeStream,
I have only had my trailer for a year and a half and one of the first things I wanted to do was to replace the Sony. I took it in to a local stereo shop and the guy there told me it was fine. He even showed me how to use the remote which, by the way, was very confusing. I tried reading the literature but that is another story.
We do not listen to much music when we camp but do when on longer trips. I picked up a cord at Target ($5.99) that plugs into the iPod and has two leads, one white, the other red, that plug into the jacks on the side in the cabinet.
The sound is great but you need to use the iPod to control things and it does not charge while plugged in. For us, it is fine. I read about the connector here on the forum some time ago.
Dick
aftermath is offline   Reply With Quote
Old 04-05-2011, 10:41 AM   #13
Well Preserved
1993 21' Sovereign
Most newer Airstreams have tge 12v lighter Plug near tge stereo, you can plu in the charger for an iPod there. I have to run to Best Buy in the next day or so to buy a replacement for a stolen radio, I'll look over the selection and see if I can take some pics of their offerings, as well as the stereo removal tools.
Originally Posted by aftermath View Post
CanoeStream,
Dick
Old 04-05-2011, 11:16 AM   #14
Originally Posted by overlander63 View Post
Most newer Airstreams have the 12v lighter Plug near the stereo, you can plug in the charger for an iPod there. I have to run to Best Buy in the next day or so to buy a replacement for a stolen radio, I'll look over the selection and see if I can take some pics of their offerings, as well as the stereo removal tools.
Terry, have you observed how a number of 12v plugs in Airstreams are so very tight when trying to insert any 12v male plug? Suggestions?
What's the "wet weight" of a 1963 Bambi ? Aktundra 1961 - 1963 Bambi 3 04-20-2011 01:35 AM
Cost to repair 02 Bambi & approx. value as is au_ee Ribs, Skins & Rivets 0 03-21-2011 04:02 PM
Love my T@B, but looking for a vintage Bambi BambiWannabe Member Introductions 3 03-13-2011 09:17 PM
Another VIN question....Bambi, but what year? Becky B. Title, VIN & Registration 6 03-09-2011 07:00 AM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
