Old 04-05-2010, 09:48 PM   #1
Plaquemine , Louisiana
For Digital TV Signal, is Antenna Booster necessary?
When I scan for channels with the booster ON or OFF, I only pickup 5 channels.
When I scan for channels with the booster bypassed (cable hooked directly from antenna to the TV), I get 19 channels. Is my antenna booster faulty? Are antenna boosters really needed for digital signal?
86 Sovereign, original old timey antenna. no batwing
Thanks, Mitch
cmkirkland is offline   Reply With Quote
Old 04-05-2010, 10:04 PM   #2
Kmpro
kmpro's Avatar
1984 31' Airstream310
Lubbock , Texas
Post Digital TV Signal
CM;
In order for me to get all the digital channels I have to have the booster on. Sounds like your booster is on the fritz to me, but I'm no TV repairman. You might be in the market for a new antenna and booster.
Mike
A Man has got know his limitations-Dirty Harry
That's Some Bad Hat Harry-Jaws 1978
kmpro is offline   Reply With Quote
Old 04-05-2010, 10:26 PM   #3
Ottawa , ON
Two comments: if you can get 19 channels with no booster, don't bother with a booster, you'll likely not do much (if at all) better with one.
Also, your old booster is possible defective as kmpro mentioned, but more likely it just may not have been made to pass the frequencies that your digital signal presents it.
Hope that helps...
Old 04-05-2010, 10:45 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Your booster is bad. Mine took a dump. I replaced it, much better now.
Most RV parts places have them.
Replacing is a ten minute job.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 04-05-2010, 10:50 PM   #5
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
I get far better reception with the booster than without. I side with the others. Replace it and see if you see an improvement. On the one in the bedroom I found the outer coax shield was no longer attached on the rear of the unit. Repair to the cable end was my solution for return to complete reception.
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 04-05-2010, 10:50 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Home Depot, WalMart, Lowes, Radio Shack, and others have them too.
Most expensive would be RV places, followed by Radio Shack, then the Big-Boxes.
Vaughan
Old 04-05-2010, 11:32 PM   #7
JFScheck's Avatar
Rockville , Maryland
Images: 33
Remember - Digital means "0's & 1's" - vice the older "Analog" signals of old so either your gonna get a signal or NOT get a signal....
I don't really understand how a "booster" can do anything to increase the digital signal unless somehow it makes the antenna "more sensitive"....
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-05-2010, 11:41 PM   #8
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
It's an amplifier. A weak digital signal is seen by your TV as no signal. Amplified, the weak signal becomes a good signal for your digital TV tuner.
It does work.
Old 04-06-2010, 06:25 AM   #9
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yeah, its still "a radio". nothing has changed, there. RF is RF, and a week signal is a week signal. The need for an amplifier is probably even greater, since the change-over to digital, because most of the broadcasters have reduced the signal strength.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Chuck is online now   Reply With Quote
Old 04-09-2010, 10:29 AM   #10
Update: Found faulty transformer and coax connection on antenna. The transformer is the gadget that adapts the two wires to coax cable. Purchased new transformer from Radio Shack, checked all connections along circuit, antenna booster now working. I believe the bulk of my problem was faulty connections. Now I get 5 channels booster off, 14 channels booster on. Don't know how I received 19 channels earlier, It would not do it again. We only have 5 channels in this area, with each transmitting 3 or less digital signals.
Thanks for the feedback.
Mitch
Old 04-09-2010, 12:28 PM   #11
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Mitch,
About the booster: in my experience, if I choose to use over-air signals, the booster must be turned on. If I use the cable hookup, then the booster must be off. One must scan each time you switch from one to the other (antenna vs cable).
Pardon me if this is the way you are using yours, but I couldn't quite tell.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 04-09-2010, 01:44 PM   #12
Good point Pat,
I was specifically talking about over the air. And yes, those boosters don't work with cable signal.
I also rescanned with every change during trouble shooting.
Mitch.
Old 04-09-2010, 01:45 PM   #13
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yes, well, some booster units are not "just" amplifiers; its also a "switch", although, it doesn't actually say that on the label. If you don't have the booster on, there is no connection to the antenna at all. so it won't work "at all". when the booster is off, the cable signal is connected; when the booster is "on", it connects the antenna, boosts the signal, and cuts off the cable connection.
Air:291
Wbcci: 3752
'73 Safari 23'
No antenna signal with digital TV Stream 1529 Audio, Video & TV 18 08-22-2009 05:52 PM
Best antenna for digital TV Lumatic Audio, Video & TV 14 01-18-2009 09:27 AM
Digital TV and Batwing Antenna jcanavera Audio, Video & TV 16 02-12-2008 07:09 PM
tv signal booster joel Electrical - Systems, Generators, Batteries & Solar 4 08-23-2006 11:05 PM
Where is the TV Antenna Power Booster - 2005 Classic? classic67 2001 - 2005 Classic 9 07-29-2006 07:58 AM
