Old 12-29-2008, 04:30 PM   #1
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
FM antenna?
Anyone know a source for this antenna? I need two of them. Either type would be fine.
The Overlander antenna is extendable, like old car antennae.
Name:	IMG_8773 overlander base-s.jpg
ID:	73078 Click image for larger version
Name:	IMG_8774 overlander ant-s.jpg
The Caravel antenna is just one piece of stiff rod with a ball end.
Name:	IMG_8775 <a title=caravel ant-s.jpg Views: 162 Size: 109.5 KB ID: 73080" style="margin: 2px" />
All I can find are CB-type. None with the original mounting swivel and spring.
Zep
Old 12-29-2008, 05:15 PM   #2
Community Organizer
Guido's Avatar
2005 22' Safari
South Chicago , Illinois
Try an auto parts store. The universal swivel-base antenna should stil be available. It will be a not-bendable one.
Fr. Guido
"We have just religion enough to make us hate, but not enough to make us love one another." Jonathan Swift
Guido is offline   Reply With Quote
Old 12-29-2008, 05:16 PM   #3
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Zep,
Found it at NAPA back in the summer. It was in stock at my local store so it must be commonly available. Our store is kinda small. The one I got is extendable.
I don't have the packaging with the part # anymore but I originally saw that in another thread post so maybe you could find that.
Good Luck,
TB
tinbender is offline   Reply With Quote
Old 12-29-2008, 05:16 PM   #4
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Hi Zep, glad to see you made it back in one piece. I too could use a new one of these for our 69. It is identical. Be forewarned that on both our 69 and the 66 we traded with Rob, the antennas were installed with pan head machine screws with lock washers and nuts on the inside, so in both cases it required removal of interior skin to get to. None of the autoparts stores or radio shack had anything close here.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 12-29-2008, 05:17 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Zep,
Not sure if you still have the bases on the trailers. Our antenna was just rusted and bent up. Found one at Auto Zone that has the ball and spring base with an AM booster coil on the extendable shaft. Attached it using the old base and half the ball that will stay with it attached to the new antenna using half of its ball.
Old 12-29-2008, 05:18 PM   #6
goransons's Avatar
1963 22' Safari
Ganglin, do you happen to know the part number at autozone? Pretty new company in our area (they just moved into town last year) but didn't see anything on the shelves here.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 12-29-2008, 05:24 PM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Don't recall and can't find it on their web site. I'll check tomorrow and let you know.
All they have listed is this solid shaft type.
http://www.autozone.com/R,2226701/st...ductDetail.htm
Old 12-29-2008, 06:14 PM   #8
1975 31' Sovereign
1977 23' Safari
Originally Posted by Ganglin View Post
Looks good, from what I can see, except that for FM reception around 90 mHz, the antenna whip needs to be 62 inches (95% of the half-wave length) or so.
Anyone know what year Airstream went to one antenna (the TV type) for both radio and TV? I know it was '73 or later.
By the way, as we all know NPR stations hover in the 88.5 to 91.5 mHz range. Is there anything else worth listening to?
Zep
Old 12-29-2008, 06:21 PM   #9
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
XM NPR and more
Zep
Hi Roger, I am very much into XM--besides the music, NPR, Cspan and they have the old radio shows--like "Our Miss Brooks" and stuff we listened to before we had TV (Televisions not Tow Vehicles) or were even born. Now I guess that dates me doesn't it?
Your trip sounds like quite an adventure......try again in the spring......paula
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 12-29-2008, 06:56 PM   #10
1975 31' Sovereign
1977 23' Safari
Originally Posted by SteSpot View Post
...the old radio shows--like "Our Miss Brooks" and stuff we listened to before we had TV (Televisions not Tow Vehicles) or were even born. ...
When I was a kid, the trick was to have the bedside [tube] radio under the bed and turn it on after your were sent to bed. Then you could listen, very quietly, to X-1, Fibber McGee and Molly, Jack Benny and Rodchester, Gunsmoke (Matt Dillon played by William Conrad), and every kind of dective show... we didn't have TV in Europe in the 50s. Thank Dog.
By the way, my partner is "Miss Brooks"--same glasses.
Zep
Old 12-29-2008, 07:16 PM   #11
SteSpot's Avatar
1968 28' Ambassador
Zep
Cool glasses!!!
And yes, Fibber McGee & Molly and the others you mention....they even have the old ads on XM........anyway, we are making room for XM in our new old soon to be finished trailer...and we are keeping our old FM antenna as well.....pj
Paula & Ed
Suite Spot
1968 28'Ambassador
Old 12-29-2008, 07:48 PM   #12
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Zep
Yes, AM late evenings in the summer. Where our trailer is currently parked outside of Columbus - antenna fully extended and the right weather... I've picked up Chicago, Atlanta, Charlotte, St. Louis, Richmond, Nashville, NY,
a station out of Canada and others in between. I think it's a left over childhood thing also.
Old 12-29-2008, 08:13 PM   #13
Ottawa , ON
If your ride is a classic AS TT, why not listen to a "classic" type of radio: a good AM station?
Two based in Toronto, and broadcast with enough strength that they can be picked up well into the US are AM680 and AM740.
Give them a try, no matter how far south you are of us, especially at night: you just might be pleasantly surprised!
Old 12-30-2008, 06:27 AM   #14
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Zeppelinium,
If you like old time radio you should check out this website.
Old Time Radio Show Catalog (OTRCAT): comedy, drama, detective,
I have purchased many items here. I have the whole collection of Jack Benny (939), Fibber McGee (733), Gildersleeve (510), a couple of Burns/Allen (274) and You Bet Your LIfe (131) programs. I would love to have more Burns/Allen but they are tough to find. The programs are in MP3 format. It's pretty wild to have 90 MP3 half hour programs on one disk.
BTW - you should turn off the FM and come back to the AM side of things and listen to real radio
crispyboy is offline   Reply With Quote
Need a better FM antenna silverback Audio, Video & TV 10 04-02-2006 06:38 AM
Which TV antenna? Ohanastar Audio, Video & TV 2 09-05-2005 12:58 PM
CB Antenna wyhjr Electrical - Systems, Generators, Batteries & Solar 14 05-02-2004 01:12 PM
cb antenna norbert Our Community 12 06-19-2003 09:57 PM
TV antenna davidz71 Audio, Video & TV 14 03-14-2003 08:14 PM
