Old 12-30-2008, 03:11 PM   #15
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Originally Posted by Ganglin View Post
Zep,
Not sure if you still have the bases on the trailers. Our antenna was just rusted and bent up. Found one at Auto Zone that has the ball and spring base with an AM booster coil on the extendable shaft. Attached it using the old base and half the ball that will stay with it attached to the new antenna using half of its ball.
OK so the memory is bad - not Auto Zone - it's Advance Auto Parts (they're on oppposite corners in our little burg).
Antenna is a Metra Universal - Part Number AT US 23. Price is right at $10.00 - especially since your throwing a bunch of it away. Zep - the shaft extension is 53" max..
Need a better FM antenna silverback Audio, Video & TV 10 04-02-2006 06:38 AM
Which TV antenna? Ohanastar Audio, Video & TV 2 09-05-2005 12:58 PM
CB Antenna wyhjr Electrical - Systems, Generators, Batteries & Solar 14 05-02-2004 01:12 PM
cb antenna norbert Our Community 12 06-19-2003 09:57 PM
TV antenna davidz71 Audio, Video & TV 14 03-14-2003 08:14 PM
