Old 04-15-2015, 07:02 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Flat screen recommendations
I am looking for information and recommendations on flat screens:
1. 12 volt/ 110 models
2. Combo TV/ DVD players
3. Shelf top vs. wall mounted TVs
4. 110 to 12v inverters
I have a 21" Sharp TV/ DVD 110 v. model. It works OK but not enough volume and is a little small. Also no 12v, so I need to run a genny when off the grid. I never tried an inverter. I just got a 93 Excella 1000 and we are looking for a new TV.
Marshall
Old 04-15-2015, 06:10 PM   #2
Lumatic's Avatar
1993 34' Excella
Images: 16
I see smallish 12v TV/DVD combos at the Camping World website. Also see larger 12v TV only. Are there any 12v/110v combo DVD players available?
Old 04-15-2015, 06:48 PM   #3
Wayward's Avatar
Cary , North Carolina
I found a Vizio LCD flat screen that runs off of a 12vdc wall adapter (brick). It is wired directly into the Airstream's 12v system so..... it runs while the Airstream is on batteries or shorepower.
My install details are in this thread. See post on page 2.
Electronics run on DC internally. Inverters are very inefficient to run an LCD TV. You lose battery power in the inverter converting to AC, and then lose again in the TV set's brick or internal converter going back to DC.
Direct wired to the Airstream 12v, with HD TV from the antenna, at about half volume, the set draws 1.9 amps. Parasitic draw is less than 0.02amps.
Our set is a few years old now so model numbers change. It can be hard to locate which sets have 12vdc wall adapters. What I do is find the model number, go to manufacturer website and look at the set's PDF manual to see what the brick's DC output voltage is. You can do the same to find home DVD/blueray players that can be direct wired to 12v in the Airstream
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 04-19-2015, 11:35 PM   #4
68Streamline's Avatar
Cerritos , California
I have been using an 22" Insigna tV/DVD combo. It runs on 12v and is available at Bestbuy.
68Streamline is offline   Reply With Quote
New Flat Screen TV Bracket Airhog1 Commercial Listings 36 02-20-2013 05:45 AM
Flat panel TV recommendations? Garfield SS model 30 04-16-2008 09:38 PM
Flat Screen Lcd Tv - 12v Or Inverter? Phantom Audio, Video & TV 13 08-25-2007 09:23 AM
Flat Screen Television Circuit JmesDean Electrical - Systems, Generators, Batteries & Solar 4 07-08-2004 11:58 AM
Thoughts on flat screen tv yukionna Off Topic Forum 15 09-16-2003 08:40 AM
