10-03-2009, 05:03 PM
Wheels Itch)(Must Travel
2014 25' FB Flying Cloud
- east coastal area -
external stereo / audio jack 2005 AS CCD
dear fellow streamers,
i have located what is listed as the external audio jack in case we want to sit outisde and listen to music from the inside cd player.
it looks like this:
i was expecting a standard audio "plug".
how do i connect speakers to this?
any info greatly appreciated,
az-streamer
az-streamer
Jon & Deb
Phoebe & Ellis - The Airstreaming Mini-Schauzers
[CENTER][I]
10-03-2009, 07:27 PM
2006 22' International CCD
1957 26' Overlander
Plymouth
Where is that plug located on your trailer? I have a 2006 22'CCD and would like to see if mine is prewired for that plug. Thanks in advance!!
10-03-2009, 10:41 PM
the plug is on the "passenger" right-hand side, near the bottomo edge, a couple of feet forward from the rear bumper.
hope this helps,
az-streamer
az-streamer
Jon & Deb
[CENTER][I]
10-04-2009, 05:03 AM
2005 19' Safari
1968 24' Tradewind
Rural
, Delaware
It's a standard four way flat trailer connector. It came on our 2005 Bambi as part of the Audio/video package. As soon as I locate my multi meter, I will find out which wires are the right/left leads and grounds. Airstream covered the wires with tubing and changed the color coding somewhere inside.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
10-04-2009, 05:26 AM
2005 19' Safari
1968 24' Tradewind
Rural
, Delaware
Whoops!
I did a quick search and found that we addressed the external speaker plug a couple of years ago. Attached is a PDF file from Airstream that has the wiring setup.
Briefly:
White----- LEFT +
Brown----- LEFT -
Yellow---- RIGHT +
Green----- RIGHT -
Hope this helps.
2005 Bambi
1968 Trade Wind
WDCU
10-06-2009, 04:10 PM
SilverRanger -
thanks for the detailed reply. now i know what to look for next trip to the rv store. since we bought this 2005 a little while ago this wiring harness was apparently not included.
-also- do the external speakers need to be hard-wired into this harness? most new speakers already are fitted with "standard" audio plugs which would have to be removed.
az-streamer
az-streamer
Jon & Deb
[CENTER][I]
10-06-2009, 04:18 PM
1957 26' Overlander
Plymouth
az-streamer Thank you for your reply. I will be at my trailer tomorrow and will see if I can find the wires. I didn,t order it with external speakers but I get the impression that many time these trailers are prewired for all options. Thank you again Brad
10-06-2009, 04:52 PM
2005 19' Safari
1968 24' Tradewind
Rural
, Delaware
"do the external speakers need to be hard-wired into this harness? most new speakers already are fitted with "standard" audio plugs which would have to be removed."
It depends on the type of speakers you get. Some speakers come with the red/black RCA type plugs (like the red one pictured). Others use either a clamping, or binding post device (pictured).
Airstream used the 4 way flat trailer connector with about 1 foot of cable. They spliced it to longer color coded wires under split loom tubing cover. At the speaker end the wire is attached to positive/negative binding posts.
Most of the better speakers have the binding post type connection. I suggest some nice outdoor (weather resistant) speakers. Most of those come with clamp or post type connections. The tubing cover (also pictured) is a good idea. It hides the splice, and helps keep the wires from tangling. Airstream included about 20 feet of cable for each speaker, which was way too much for me.
Good luck!
2005 Bambi
1968 Trade Wind
WDCU
10-10-2009, 03:07 PM
Silver Ranger,
thanks AGAIN for even more useful info.
It will make this project much easier now that I know what to look for and what to do with it when i find it.
az-streamer
az-streamer
Jon & Deb
[CENTER][I]
