Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 10-03-2009, 06:03 PM   #1
az-streamer's Avatar
Profile:  2005 22' International CCD
Cave Creek , Arizona
external stereo / audio jack 2005 AS CCD
dear fellow streamers,
i have located what is listed as the external audio jack in case we want to sit outisde and listen to music from the inside cd player.
it looks like this:
i was expecting a standard audio "plug".
how do i connect speakers to this?
any info greatly appreciated,
az-streamer
az-streamer
az-streamer is offline   Reply With Quote
Old 10-03-2009, 08:27 PM   #2
BradS's Avatar
Profile:  2006 22' International CCD
Plymouth , Minnesota
Where is that plug located on your trailer? I have a 2006 22'CCD and would like to see if mine is prewired for that plug. Thanks in advance!!
"You can't always sometimes tell" John D. Newman
BradS is offline   Reply With Quote
Old 10-03-2009, 11:41 PM   #3
the plug is on the "passenger" right-hand side, near the bottomo edge, a couple of feet forward from the rear bumper.
hope this helps,
az-streamer
az-streamer
Old 10-04-2009, 06:03 AM   #4
SilverRanger's Avatar
Profile:  2005 19' Safari
1968 24' Tradewind
Milton , Delaware
It's a standard four way flat trailer connector. It came on our 2005 Bambi as part of the Audio/video package. As soon as I locate my multi meter, I will find out which wires are the right/left leads and grounds. Airstream covered the wires with tubing and changed the color coding somewhere inside.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WBCCI# 4582
WDCU
SilverRanger is offline   Reply With Quote
Old 10-04-2009, 06:26 AM   #5
1968 24' Tradewind
Milton , Delaware
Talking Whoops!
I did a quick search and found that we addressed the external speaker plug a couple of years ago. Attached is a PDF file from Airstream that has the wiring setup.
Briefly:
White----- LEFT +
Brown----- LEFT -
Yellow---- RIGHT +
Green----- RIGHT -
Hope this helps.
2005 Bambi
1968 Trade Wind
WBCCI# 4582
WDCU
Old 10-06-2009, 05:10 PM   #6
SilverRanger -
thanks for the detailed reply. now i know what to look for next trip to the rv store. since we bought this 2005 a little while ago this wiring harness was apparently not included.
-also- do the external speakers need to be hard-wired into this harness? most new speakers already are fitted with "standard" audio plugs which would have to be removed.
az-streamer
az-streamer
Old 10-06-2009, 05:18 PM   #7
BradS's Avatar
az-streamer Thank you for your reply. I will be at my trailer tomorrow and will see if I can find the wires. I didn,t order it with external speakers but I get the impression that many time these trailers are prewired for all options. Thank you again Brad
Old 10-06-2009, 05:52 PM   #8
1968 24' Tradewind
Milton , Delaware
"do the external speakers need to be hard-wired into this harness? most new speakers already are fitted with "standard" audio plugs which would have to be removed."
It depends on the type of speakers you get. Some speakers come with the red/black RCA type plugs (like the red one pictured). Others use either a clamping, or binding post device (pictured).
Airstream used the 4 way flat trailer connector with about 1 foot of cable. They spliced it to longer color coded wires under split loom tubing cover. At the speaker end the wire is attached to positive/negative binding posts.
Most of the better speakers have the binding post type connection. I suggest some nice outdoor (weather resistant) speakers. Most of those come with clamp or post type connections. The tubing cover (also pictured) is a good idea. It hides the splice, and helps keep the wires from tangling. Airstream included about 20 feet of cable for each speaker, which was way too much for me.
Good luck!
ID:	88379   Click image for larger version
Name:	5-way binding post.jpg
2005 Bambi
1968 Trade Wind
WBCCI# 4582
WDCU
Old 10-10-2009, 04:07 PM   #9
Silver Ranger,
thanks AGAIN for even more useful info.
It will make this project much easier now that I know what to look for and what to do with it when i find it.
az-streamer
az-streamer
Any way to get DVD audio through the Aquos LCD in my 2005 Safari??? MG911 Audio, Video & TV 3 07-16-2009 11:20 PM
External Speaker Jack - 2005 Int'l 25SS jsprad Audio, Video & TV 11 12-04-2007 05:15 PM
2005 CCD electrical issues ablaze Electrical - Systems, Generators, Batteries & Solar 7 10-29-2007 06:57 PM
Externial Audio Input thru Stock Stereo? Bambi_Bandit Audio, Video & TV 7 07-17-2005 11:37 AM
2005 22ft CCD on it's way!!! Oooh! Foiled Again Our Community 0 03-20-2005 07:27 PM
