Old 09-25-2013, 11:40 AM   #1
rogerdodger's Avatar
Fresno/Clovis , California
Enclosure for 5 1/4" speaker
I am replacing the 5 1/4" speakers, and they are wall mounted, with nothing behind them but the outside wall, and open to the interior space between the walls. If I make small enclosures from cardboard between inside wall and outside wall, will this improve the sound, or install them as the old ones are installed? Thanks in advance for the help.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 09-25-2013, 12:14 PM   #2
SteveH's Avatar
Common Sense , Texas
As an old time audiophile, I don't think anything you can insert into the wall area would have large enough volume and be ridged enough to improve the sound quality, and might even vibrate and cause a buzz. You might help things by adding additional insulation in the area of the speaker, but IMHO that's about it.
Regards,
Steve
Old 09-25-2013, 12:29 PM   #3
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
speakers
I recently replaced my original 73 speakers. I got good replacement ones, (JBL's)and they mounted into the original speaker grates. The cone was deeper and I easily found speaker spacers in the right size(internet), got longer screws and was done. I used automotive sound deadener (Dynomat) on the inside of the outer shell. Much improved sound!
moparjohn is offline   Reply With Quote
Old 09-25-2013, 12:39 PM   #4
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Just the fact that they are bolted in will give full range sound.
When speakers are mounted on a baffle board only they are "free air"- meaning an enclosure is not necessary.
An enclosure only matters on bass response- subwoofers.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-25-2013, 06:09 PM   #5
SteveH's Avatar
Better quality drivers will almost always provide improved sound quality.
Regards,
Steve
Old 10-03-2013, 09:05 PM   #6
I replaced the speakers and installed a new stereo CD player, all from Crutchfield. 4 Sound Ordnance P-52 5-1/4" 2-way Spkrs, 3/4" Silk Dome, and a Pioneer DEH-150MP CD Receiver. Awsome sound. I used the original speaker enclosures. Thanks for the info and encouragement.
Roger
Air# 29488
Old 10-03-2013, 09:17 PM   #7
Ottawa , ON
I think that the best ways to make significant improvements are
  1. Improve the driver (a la JBL mentioned above)
  2. reduce various and sundry buzzing and rattling such as the use of Dynomat or similar
  3. reinforcing the panel the speaker sits on, by perhaps gluing and screwing 3/8" plywood to the back, front, or both.
A subwoofer will add much more bass, but will require a more significant investment of money and space.
Old 10-03-2013, 10:52 PM   #8
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
If you really enjoy enhanced music and can figure how to run/hide wires, find a spot for this item:
Jensen JXA8BA2 8" Amplified Subwoofer
SeeMore is offline   Reply With Quote
Old 10-04-2013, 03:56 AM   #9
m.hony's Avatar
2013 30' Classic
That powered sub would go behind/under the couch.
TAC #MS-10
Airforums #70955
Old 10-04-2013, 05:49 AM   #10
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Gave up on the Sony OEM "sound system"
This works well for the tv.
And this for the music...
....and both have applications outside the AS.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
