Old 12-02-2007, 08:15 PM   #1
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Do you remove the TV in winter?
My Safari came with a Samsung HDTV. I looked in the Samsung owner's manual and it said the temperature limits for the TV were -4˚ and 113˚.
I imagine there's a way to unhook it from the mounting bracket and all those wires are a lot less than on my living room home theater setup, but I'm not looking for another thing to do.
In the summer, I'm sure temps in the trailer can go over 113˚, but I'm not about to remove it every time it's hot.
In a few weeks it could be below zero here in the morning, so I'd better get slightly motivated.
Anyone remove their TV's in winter?
Gene
Old 12-02-2007, 08:35 PM   #2
_
Originally Posted by CrawfordGene
...Anyone remove their TV's in winter?..Gene
not me.
there are several threads on this topic (some are funny)
i think the BIG issue long term (over years) is that the electronic connectors, adhesives and board goo can dry out.
there are tv/video makers that have 'rv/marine' models
reported to have more durable connectors, better resistance to vibration, thicker adhesives, goo and so on...
that info has been posted also.
is there an lcd screen in your truck? how about the sony radio face in the trailer?
my solar display monitor is also lcd.
obviously you aren't going to watch tv at 5 below,
and warming/cooling should be at a gradual rate.
i think the sony models have a slightly wider temp range than you've posted for s-sung, but not much.
did you notice there are also altitude parameters for these tvs and cameras and computers...
some of this stuff is like 'expiration dates' on bottled water
cheers
2air'
Old 12-02-2007, 09:15 PM   #3
bobandcarla's Avatar
2005 25' Classic
Pelham , New Hampshire
Short and simple. Yes.
Bob & Carla
05 classic 25'
WBCCI # 1836
bobandcarla is offline   Reply With Quote
Old 12-02-2007, 09:20 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Why?
Vaughan
Old 12-02-2007, 10:54 PM   #5
zamboni's Avatar
"Short and simple."
Does that mean you're not tall and not very bright!? Just couldn't resist...it getting late and I should be asleep.
zamboni is offline   Reply With Quote
Old 12-02-2007, 10:56 PM   #6
zamboni's Avatar
"Do you remove the TV in winter?"
I originally thought this was going to about tow vehicles...kinda obvious you'd remove it in winter.
Old 12-03-2007, 01:15 AM   #7
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
We did last year, we did not this year. I think it is as 2Air replied. The dealerships do not remove them as they winter in the lots. But it is not that difficult to remove it. I kind of like it being there in case I go out to the AS and want to watch a little tv. One less thing to monkey with for a trip or store in the house. Being cautious is always a good thing though and now I will ask hubby what he thinks again.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 12-03-2007, 02:49 AM   #8
Over a month ago I sent this question to Sony America about which of the 2 systems (LCD or Plasma) could withstand a wider temp range. I vaguely remember from a decade ago that one of them could not stand freezing temp. according to some article. I have an LCD TV/monitor in my AS and the colors are washed out at 40 F but were ok half hour later.
Live and LET live
FrenchBern is offline   Reply With Quote
Old 12-03-2007, 06:18 AM   #9
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Can you put a small electric heater in the trailer?
I don't remove my LCD tvs I move the whole trailer south!
Michelle TAC MT-0
Sarah, Snowball
Old 12-03-2007, 08:13 AM   #10
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
This was a big question for us at work a few years ago. All of our research stations on our C130 have flat screen moniters mounted to the front. We were spending a winter flying between Churchhill Manitoba and Thule Greenland with the aircraft cold soaking at night. We did some tests in our temp chamber, and found out that the critical temp was the temp where the moniter was turned on not setting static. So as long as we did not turn them on below the rated temp they were fine. At the high end they just shut down until they have cooled.
For what its worth the cabin would cold soak to around -30 C and it would take about 3 hours to bring it up to zero C before we turned on any of the moniters
Old 12-03-2007, 09:08 AM   #11
Master of Universe
Gene's Avatar
I figured the radio is a car model, so it probably has a wider temperature range, though I didn't check. I don't know how 2air finds all these threads, but I did find something about someone removing the monitor panel. The Samsung says not to use it below 50˚—probably explains why FrenchBern's colors are washed out at 40˚.
Barb suggested an electric heater, but my thought is it would use a lot of electricity and rates keep going up. If the heater could be set to 10˚, maybe that would be a good idea, but I doubt they have that kind of temp control.
I have noticed some electronics have altitude parameters, but didn't check that as I don't want to bury the Safari to meet the altitude range.
It doesn't often get below -10˚ here and I may be able to rationalize that Samsung gives very conservative ranges, so I'm ok. Not sure what to do.
Gene
Old 12-03-2007, 10:36 AM   #12
ScottW's Avatar
Hernando , Mississippi
Nope!
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 12-03-2007, 01:50 PM   #13
2005 25' Classic
Originally Posted by vswingfield
Why?
In the winter I let the grandchildren watch the tv in the spare bedroom but I thought it was a good idea just because of the cold. I guess from reading this it's ok to leave it in but it's not a big deal to take it out.
Bob & Carla
05 classic 25'
WBCCI # 1836
Old 12-03-2007, 01:56 PM   #14
2005 25' Classic
Originally Posted by zamboni
"Short and simple."
Bob & Carla
05 classic 25'
WBCCI # 1836
Can't Remove Window bentguy Windows & Screens 7 10-01-2008 11:47 PM
What will remove this stuff? jdalrymple Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-09-2007 08:14 PM
need to remove frig from '73 rhodyrunwv Refrigerators 3 05-13-2006 09:25 PM
Can I remove and discard these??? Ed Starman General Interior Topics 1 01-30-2005 08:41 PM
Difficult to remove AC? 71_safari Furnaces, Heaters, Fireplaces & Air Conditioning 5 07-02-2004 07:04 PM
