08-02-2011, 10:51 PM
1974 25' Tradewind
Berryville
, Virginia
Ditch the antenna?
I have a old style antenna on my trailer and was thinking of removing it and patching the hole since everything is now digital and sat any opinions on this? Is this a good place to put a dish?
08-02-2011, 11:26 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
The antennas pickup digital signals over the air just fine. The local channels for Little Rock on Dish are not HD. I get them over the air on my antenna and can even record them on my Dish DVR using its over the air tuner.
I wouldn't be without my antenna. It also serves as the radio antenna for my '83 Excella, another reason to have one.
Vaughan
08-03-2011, 06:42 AM
Airstream - Other
Bosque Farms
, New Mexico
We use our old-style 1967 antenna plenty with digital TV. Works a lot better than the portable flat-panel thingie we bought when we got the new TV!
Lynn
ACI Big Red Number 21043
08-03-2011, 06:53 AM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
In reality there is no such thing as a digital antenna just as there really was no such thing as a "color" antenna. The major differnce with off the air digital is it requires a stronger signal to lock and is either go or no go. The old antenna should work fine . In addition many channels were forced to move to UHF during this change. I would not want to give up off the air capability by removing the antenna and replacing it with a dish.
A roof mounted dish is probably more convenient than a portable one but has the disadvantage of not being re-locatable if signals are blocked by trees on your campsite
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
08-03-2011, 08:00 AM
1968 28' Ambassador
Cedaredge
I ditched mine, PO put a new one on the roof. I patched the hole on the front of the trailer with a flag holder.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
08-03-2011, 08:11 AM
2000 25' Safari
Davidson County
, NC Highlands County, FL
With the original equipment antenna and the original equipment 12v amplifier I get 26 digital channels while at home. While in the mountains camping a few weeks ago I could only get two channels at one location and only one channel at another location. It's all about the signal available at a specific location.
Alan
08-04-2011, 12:05 PM
vintage travelers
1972 31' Sovereign
Johnson City
, on the road
We removed ours bought a sat dish at camping world the cheep one wineguard the mount was a good fit to the old att hole no cutting and inside only 1/2 inch of enlarging it has a duel hook up so we could use our dish dvr and lock onto sat 119, good to go the unit cost 135. and 1 hour work not bad, for over the air we have a hd digital that we put on our flag pole mount when we are in an area close to get over the air channels.
HAPPY CAMPING IS WHERE THE SLIVER LEADS US
08-04-2011, 02:17 PM
1965 22' Safari
Vassar
, Michigan
I got rid our ours and patched the hole. We use a Sat. most of the time but I do have a winguard tV antenna that I can raise on our flag pole. We boondock most of the time in areas that have little or no local air tv.
Tim
TAC MI 14
Everyday is a Saturday
08-07-2011, 09:09 AM
1974 25' Tradewind
Berryville
, Virginia
Thanks for the input, I will now keep the antenna. I had thought about replacing it with a sat dish but the information now leads me to just having it as a portable unit on a stand.
08-07-2011, 09:18 AM
1965 22' Safari
Vassar
, Michigan
Sounds like a good plan. I have 100' extention of coax cable and have the sat. dish (directv) on a small Winguard tripod. I can move the tripod to many different locations around a campsite looking for a signal. It works 95% of the time. We just pick our campsites carefully (not always possible).
Tim
TAC MI 14
08-08-2011, 09:18 AM
2006 28' Safari SE
Halifax
, Nova Scotia, CANADA
Keep that old antenna
I use my old antenna on the weather radio, it is much better than the built in whip.
Wineguard also sells a UHF add-on to increase gain for this antenna on digital signals. It just bolts on.
John
John
If you need to turn on your air conditioner,you've gone too far south!
2006 Safari SE 28W/LS,
2006 Silverado 2500HD/LT EC SB 4x4 Duramax/Allison,
Hensley Arrow , Honda EU2000i (propane),
160W Solar, 400W sinewave inverter,
3-stage smart charger, Xantrex battery monitor,
Sirius satelite radio
08-08-2011, 10:28 AM
Maniacal Engineer
Lopez Island
I removed ours as it was broken; I machined an aluminum cap for the rotator shaft hole as I didn't want to remove and patch the mount. In its place sit two 100W solar panels. I have no interest in watching TV in the 'stream anyway.
- Bart
