Old 05-31-2013, 10:54 AM   #29
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Originally Posted by perryg114 View Post
I think I would just move the inside unit to the trailer. Is the receiver and Hopper made into the same unit or are there two discrete boxes? I would do the free with contract deal and buy a portable dish out of pocket.
Perry
Maybe someone who has the Hopper will have specifics. The Hopper is the receiver, but I believe it requires a twin coax connection to the receiver from the antenna; not really sure how that is accomplished with the existing cable arrangement in an Airstream. This is something you might discuss with a local agent as I doubt the sales or tech support on the 800# will be conversant on what you really need. The Hopper also has a disk drive for the DVR function which may be a problem if it gets a lot of jouncing going down the road even in the absence of 110v. A simpler single tuner non-DVR receiver that uses a single coax to the antenna will still get all the channels you subscribe to, but may be easier to live with on the road.
... As I was typing as fast as I could, I see Jack covered all the details and we are on the same page on this.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 05-31-2013, 11:00 AM   #30
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Fun when we cross posts! The twin coax lead goes into the solo node. That multiplexes the signal over to a single coax connection to the Hopper. Lots of traffic in and out on that single cable between the Hopper and Solo node. That's the big reason for the 3 GHz cable.
You could have the solo node external to the Airstream and have a single lead coming in. The issue is the Airstream's internal cabling. If its not 3 GHz, all kinds of problems can occur. I'm a prime example where the original installer of my Hopper thought my cabling was just fine. The Hopper worked okay for a day and then it started having a mind of its own. A repair man came back and put an impedance meter on the cable feeding the Hopper and realized that the first guy didn't do his job right. He ran all new 3 GHz cable from the Dish all the way into the house and replaced the RG 6 cable between the Hopper and solo node with a 3 GHz run. The system has run perfectly ever since.
Personally I'm happy with the 211z receiver in the trailer. And if I want, I can turn it into a DVR by purchasing an external USB 2.0 hard drive. Dish will charge a one time fee for unlocking the hard drive service on the receiver. I think it is $45.
Jack Canavera
STL Mo.
AIR #56
Old 05-31-2013, 12:43 PM   #31
1981 31' Excella II
New Market , Alabama
We have been using Windows Media Center for a number of years and we are addicted to the skip button and watching stuff when we want to. A DVR is a must have for us. Now that we are abandoning cable and Media Center is not being supported my Microsoft, a Satellite DVR seems the way to go. 30 sec commercials on Hulu is about as long as I can tolerate commercials. I loose interest and start channel surfing.
Perry
Old 05-31-2013, 01:04 PM   #32
1999 25' Safari
Somewhere , Ohio
I started reading this thread and got through the first page, but jumped to the last, so I hope I'm not repeating something someone else has said or missed a turn in the discussion.
We have Dish in our home for years, and have had it for a couple of years in the AS. I don't know how the others here have been able to move a receiver from their home and use in their AS, but we couldn't get it to work and were told we needed a special receiver, which we bought for around $150 (I think); we use a "Tailgater" for the dish. As someone else mentioned, they allow us to deactivate the AS receiver during the Winter to avoid the monthly charge when we aren't using it.
We love having the option to watch tv while away if the mood strikes us; sometimes we use it and other times not.
Dish has recently changed their programming setup and their billing practices. We have been paying for our programming annually for some years now, saving $$ from them by paying ahead. We recently received a letter stating that they are no longer going to allow that -- I imagine it's so they don't have to discount the cost to those paying annually.
We're pretty pleased with Dish, if we call and get someone with a heavy accent, I simply say, "I'm sorry, but I can't understand you. May I please speak with someone from the US?" They aren't always happy, but in the end transfer me. If I call and by chance reach someone from the US first time................I immediately tell them how wonderful it is to be speaking with someone I can understand.
Deb
Air Cruiser is offline   Reply With Quote
Old 05-31-2013, 02:15 PM   #33
jcanavera's Avatar
Fenton , Missouri
Images: 143
Deb
Deb, if you were trying to use one of your home receivers with your Tailgater and the receiver wasn't the proper model 211, then as you noticed it won't work. The 211k and 211z receivers will work at home and with the Tailgater. Some folks use a standard dish mounted on a tripod. In those cases most of the Dish receivers from home will work.
Current pricing on the 211k is as low as $69 and the 211z is $89. Both prices are from an authorized Dish reseller on the Internet. The difference between the two receivers is that the 211z is smaller than the 211k. The 211z does not have a coaxial output for your TV. It only handles HDMI and composite cable out.
The 211z just came out in March and at the time, was not available on an individual purchase from Dish. I wanted it since I needed to have a smaller sized receiver due to the fact that the TV and receiver sit on a cabinet top over the top of our convection oven in our Classic. I bought mine from an authorized reseller.
Jack Canavera
STL Mo.
AIR #56
Old 06-01-2013, 06:23 AM   #34
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
If you have never had either DrecTV or Dish Network this won't matter, but...I have had DirecTV for years and I am used to the button layout on the remote. When I am at the kids' house or my sister's house and try to use their Dish remotes it is a challenge. All of the same functions are there, but in different places.m also the on-screen displays are different and hard to get used to after using DirecTV for so long.
Old 06-01-2013, 08:33 AM   #35
1999 25' Safari
Somewhere , Ohio
Jack, thanks for updating me on the receivers, I imagine we have the 211k since it's about two years old. We really like the fact that we can carry the Tailgater around (so lightweight!) to get the best reception.
So, if I understand this correctly, we could use the 211k in our home if we wanted? I had no idea and thought it was strictly for use with the Tailgater.
Deb
Old 06-01-2013, 08:51 AM   #36
jcanavera's Avatar
Fenton , Missouri
Images: 143
Deb
Deb, the only issue would be if you have a Hopper/Joey system installed. If you do, you would need separate coax run from the dish on the roof to the receiver.
Obviously if you don't have a Hopper then your existing wiring should support a 211k. For all intents the 211 series receiver was developed prior to the Tailgater dish and was a household unit. Some older 211 units which are not designated a k or z model, may not be able to support a Tailgater.
The folks at Dish have an RV support department and you can ask for them and discuss home use of your 211k if you have questions. I initially had some problems with my 211z on its first use and technical support transferred me to the RV support area. They gave me some initial setup solutions that got me going.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-15-2013, 10:09 AM   #37
jcanavera's Avatar
Fenton , Missouri
Images: 143
Here's some more information about my experience after my first campout with my Dish Tailgater and 211z receiver.
http://www.airforums.com/forums/f451...h-98992-3.html
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-03-2013, 01:12 AM   #38
CA_Tallguy's Avatar
1977 31' Excella 500
Zavalla , Texas
I will never use directv again. They have silly policies about transferring equipment and services to others. I had an extensive directv installation at home with 5 DVR's all networked together for "whole home" including the supersize DVR that will record 5 things at once. Altogether I could record or watch 13 programs at a time in the house! It was a sweet setup and it took the installer an entire day to complete it.
Well, I went on the road full time and when I moved, they would not let the new people in the house take over a perfectly awesome installation! They'd rather send out an installer all over again and create a hassle not only for me but the new people too!
And it was a pain to terminate - they wanted to send boxes to return equipment. So I call 2 weeks before moving and they say they can't send out boxes until you turn off the service (not in anticipation). So there was no convenient way come moving day to have tv services stop that day and then ship off the equipment at the same time.
Instead, I had to have the prepaid return boxes sent several states away and I had to pack and move the 5 DVRs to mail from that location.
But when I called to cancel after packing and getting on the road, THEN they tell me they don't even want all 5 DVRs sent back! I tried to demand that they send boxes so I could return all of them since I already went through the trouble of hauling them across several states but that didn't get very far.
I suspect that they don't allow transfers as it could be a loophole in their 2 year contract and early termination fees. But that seems too short sighted to be plausible as they spend a fortune on marketing and acquiring new customers and on install labor. I can't figure out for the life of me why they wouldn't take an already installed customer through transfers like this. Heck, instead of sending an installer to install, they could even send so done out to do paperwork if they absolutely had to for some reason.
I'm planning to install satellite in my airstream in the next 45 days or so but it will be DISH - sounds like the pay as you go plan will not have any of this funny business with it.
WBCCI #1711
Texas Gulf Coast Unit, Texas Airstream Harbor
Angelina National Forest, Zavalla, TX
CA_Tallguy is offline   Reply With Quote
Old 07-03-2013, 06:08 AM   #39
1981 31' Excella II
Well I just signed up for DISH and the Hopper DVR works great but the web interface viewer thing does not work well. This feature was oversold and now I am going to have to pay extra to get a box put in the bedroom. If you get a new system get all the extra room boxes while you can get the free installation.
Perry
Old 07-03-2013, 06:32 AM   #40
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
More Tailgater stuff
I went camping last weekend at a reserved spot with a not too good south sky exposure. While the tailgater only picked up one satellite this worked just fine.
