Old 01-09-2016, 11:33 AM   #1
2016 27' International
Charlottesville , Virginia
DirecTV: (1) HD?; (2) Splitting with home account
I've seen a few forums on part one of this subject, but nothing that recent. A couple of questions:
1) Has anyone found a solution for getting HD channels on their trailer through DirecTV? We are most interested in an antenna that we would set up with the rest of our camp, but would consider permanently mounting one on the roof if that's the best option.
2) For folks who have DirecTV in their homes as well, are you able to share a single account, and thereby only pay one monthly fee or do you have to pay double for the two set-ups?
BugsyJ is offline   Reply With Quote
Old 01-09-2016, 11:40 AM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
If you get a portable dish and take your box from home you should be good to go. We have Dish network, however, we have several friends who subscribe to Direct and this works for them.
You will, of course, have to learn to set up the dish.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 01-10-2016, 09:16 AM   #3
Thanks. I'm wondering if I can get Hi Def through DirecTV or just standard definition.
Old 01-10-2016, 09:40 AM   #4
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
The answer is yes, but u must use the type of antenna that is usually mounted on your roof. The antenna can be portable if u desire. The RV service is only an additional receiver, It must not be part of a genie system.
jkcru is offline   Reply With Quote
Old 01-10-2016, 10:46 AM   #5
2014 Interstate Ext. Coach
fairfax station , va
Direct TV for "Settlers"
You can only get standard def with most portable dishes (like King Quest) because you actually have to lock on to three satellites for HD; 99, 101 and 103, I believe. The King only finds 101.
An additional receiver costs only $6 per month added to your bill, so it's actually a lot cheaper than Dish pay as you go.
VAtom is offline   Reply With Quote
Old 01-10-2016, 10:53 AM   #6
2004 28' International CCD
Cocoa , Florida
Directv charges $5.99 a month for additional box. If you want to look at and touch, camping world has portable dishes, but I suggest you see what you want and then go the Amazon route. You'll save a bunch. Setting up and getting a signal might test your patience a bit, but once you do it once or twice, you'll be a pro. I did it in my tractor-trailer and was able to be up and running in 3-4 minutes.
Good luck!!
Bhkh226 is offline   Reply With Quote
Old 01-10-2016, 11:03 AM   #7
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
We have DirecTV for our house with 3 receivers, all HD. When camping we take one of the receivers and use it in the trailer. I have both the roof top dish that is not HD and a portable one that is HD. Most of the time I end up not being able to use the roof top one due to trees being in the way I have a switch to change from either roof top or portable. At our age, we really do not see much difference in regular or HD so we do like using the roof one for convenience when possible. Price is what we pay for the house set up. Taking one of the receivers with you does not cost any more. HD satellite dish is a tad harder to aim, but sometimes the only way to get signal is to get out from under the trees. I have different length cables to have a distance of about 100' if needed.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 01-10-2016, 11:35 AM   #8
gecko's Avatar
2009 28' International
Pacific Palisades , California
We also have Direct TV with two receiver/DVR's at home. Does anyone know if it's possible to take one of the receiver/DVR's and playback pre recorded programs WITHOUT any antenna?
If so, we could set the remaining receiver at home to continue recording, and swap them out in the next trip.
gecko is offline   Reply With Quote
Old 01-10-2016, 05:02 PM   #9
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Gecko, yes, we take one of our Direct TV receivers on the road just to watch recorded programming on rainy days; no dish for us yet. Joe
jayseejay is offline   Reply With Quote
Old 01-10-2016, 05:48 PM   #10
U.S. Navy, Retired
Silverleaf's Avatar
1997 30' Excella
Cumming , Georgia
We have a dedicated receiver for the rig, but it counts as one of the home receivers and I only pay the monthly charge for the extra receiver. It needs to match whatever antenna you choose. Your home system has a SWM dish with multiple "heads" to receive the 3 satellites as mentioned above. Nearly all of the portable and rooftop dishes are non-SWM, but I've seen at least one that is SWM, but at several times the cost of the others. We settle for SD in the Airstream. This is our version of "roughing it", and so far it hasn't been a problem because we only have a 32" in the rig. The HD really makes a difference at home where the big screen comes into play.
Bill & Barbara
WBAC 3615 AIR 77452
1997 Excella 1000 Classic 30 (Silverleaf)
2015 F150 3.5L EcoBoost (Redford)
Silverleaf is offline   Reply With Quote
Old 01-10-2016, 07:10 PM   #11
Durango , Colorado
We have a Winegard Traveler Antenna for Directv. It is SWM compatible and can receive HD as well as 3D TV broadcasts. We take an older DVR Receiver from the house and use it in our trailer. No problem and no extra fees other than the normal additional receiver charge.
By the way, you can add or subtract receivers at anytime online. So if you don't want to pay year round you can deactivate the extra receiver when not in use.
The only issue you will have is with network TV channels ABC,CBS,Fox, NBC. These are only broadcast in your local area, if you go outside that area you will lose the networks.
RVDreamer is offline   Reply With Quote
Old 01-10-2016, 10:56 PM   #12
gecko's Avatar
Thanks, Joe!
Old 01-10-2016, 11:41 PM   #13
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
We have Dish network. When we travel out of our local network area, I call Dish and tell the tech person that we are no longer at zip code (where we were last) and are now at (new zip code". I also tell them that the billing address has not changed. In a few minutes I get the local networks. They always make the change.
Perhaps Direct will do the same.
A tip for setting up a three LNB satellite dish.
Cut a pop can in the middle, into two "cups". Set the dish to the settings for the zip code location. Cover the two outside LNBs. Search for the middle satellite. In my case, that would be 119, as Dish use 110,119 and 129 for our service. After I find 119, I remove the covers and, like magic, all three show up.
Old 01-11-2016, 11:34 AM   #14
1998 28' Excella
Little Rock , Arkansas
What are your thoughts on Chromecast (or similar) to satellite when camping
We can't decide whether to buy a satellite dish or just go with a smart tv and plug-in or whatever. Currently, we do not have a TV (television) in our AS. We've done fine without it but have only been on short trips as we are still newbies. Longer trips might be better with some TV, although we're not totally addicted. I'm sure this has been covered before but tech has changed so much I'd like your opinions on this subject.
1. What size smart television would you consider optimal for a 28 ft Classic?
2. Which plug-in do you use, if any?
We are not very techy! Moderately so.
Thanks1
Gillpine is offline   Reply With Quote
Frame rail is splitting CA_Tallguy Repairing/Replacing Floor &/or Frame 17 02-09-2014 10:00 PM
Whoo boy... splitting in the copper lines SUEHOWIE LP Gas, Piping, Tanks & Regulators 5 03-02-2009 04:32 AM
splitting off a/c or microwave 1994 34' Excella richinny Electrical - Systems, Generators, Batteries & Solar 6 08-04-2007 09:46 PM
Electrical Help - Splitting a receptacle COArgosy78 Electrical - Systems, Generators, Batteries & Solar 4 07-03-2005 03:57 PM
