Old 03-13-2016, 05:34 PM   #1
larry b's Avatar
1975 31' Sovereign
howell , Michigan
Digital TV signal finder
Looking at the king sure lock sl1000
Is it worth the $25-$30 bucks, anyone on here use a digital TV signal finder? Does it really help locating a better signal?
larry b is offline   Reply With Quote
Old 03-13-2016, 08:09 PM   #2
1986 31' Sovereign
Miami , Florida
Mine works fine and is helpful when I am on the edge of a reception area. If your tv has a signal strength meter on one of the menu pages, that will work just as well.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 03-13-2016, 11:08 PM   #3
2005 19' Safari
GLENDALE , AZ
We use this PC program to locate the broadcast television antennas (map shows antenna direction and distance). However, you need to know the address or zip code for where you are camped: AntennaWeb.org
Old 03-14-2016, 04:52 AM   #4
r carl's Avatar
Lin , Ne
And you need to know which way to point your antenna before you auto search for channels on your tv.
Old 03-14-2016, 04:57 AM   #5
larry b's Avatar
1975 31' Sovereign
howell , Michigan
Mike
Thanks all, didn't know this is a option on some tv' going to check my tv first.
Old 03-14-2016, 06:58 AM   #6
dznf0g's Avatar
Oswego , Illinois
I've used this one for several years for the phone. Uses GPS and works pretty well....until you have no cell signal. A handheld compass is needed to orient yourself.
https://play.google.com/store/apps/d...per.free&hl=en
-Rich-
Old 03-14-2016, 10:20 AM   #7
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I am using the Rayzar antenna from Winegard. So far so good. Actually with this antenna I have been able to get good local channels on my Airstream for the first time. Previous stock antenna's for me were pretty useless.
TinCan
graysailor is offline   Reply With Quote
Old 03-14-2016, 11:16 AM   #8
1996 25' Excella
Tillsonburg , Ontario
The search function on my old TV picks up even weak digital channels but you still need to re orient the antenna for a few channels that won't display or come in fuzzy or pixelated, and then bring it back when you change channels again. First thing you do is look at where everyone else is pointing...unless there is only you! Then I start with the unit aligned as it first comes up then try rotating 90 degrees and back until I zero in on good signals.....have to admit a signal strength indicator would be helpful.
I have an original Winegard without the digital add-on booster
JCW
JCWDCW is offline   Reply With Quote
Old 03-14-2016, 11:21 AM   #9
dznf0g's Avatar
Oswego , Illinois
The above app tells you the direction from which the signals come. Then just use a handheld compass and orient yourself and your antenna to that direction. Easy peasy!
-Rich-
Old 03-14-2016, 01:21 PM   #10
Images: 59
My handheld compass is my iPhone.
Old 03-14-2016, 01:58 PM   #11
dznf0g's Avatar
Oswego , Illinois
That's fine...it's still in your hand! Seriously, you only have to point the antenna roughly in the same direction that the majority of the signals come from. The app clearly shows that. It's not rocket surgery nor brain science!
-Rich-
Old 03-14-2016, 02:06 PM   #12
Images: 59
If you use "TV Towers USA" app the compass is buit in and all you need to do is rotate your phone so the pointer is pointed at the tower (or network) you want and then align your antenna with the iPhone.
Old 03-14-2016, 10:58 PM   #13
2007 25' Safari SS SE
Crowley , Texas
I have a pair of ball-shaped compasses, the kind that float in water, suction cupped to the ceiling, along with a quality pocket compass. I refer to them after I begun cursing the compass app on my windows phone if it takes more than one placement of the dish to find the direct tv satellite signal in the southern sky. Once the dish is aimed, it makes for another easy reference for aiming the terrestrial antenna. If only I didn't have to guess where to aim it. Sadly, there doesn't seem to be a windows app that lists the local station antenna locations. Curse the luck.
TopGeorge is offline   Reply With Quote
WBCCI Friend Finder by NOVA! DanB WBCCI Forum 37 01-12-2012 05:49 PM
For Digital TV Signal, is Antenna Booster necessary? cmkirkland Audio, Video & TV 12 04-09-2010 01:45 PM
No antenna signal with digital TV Stream 1529 Audio, Video & TV 18 08-22-2009 05:52 PM
Satellite finder--which one? Kistler Electrical - Systems, Generators, Batteries & Solar 8 11-27-2004 08:58 AM
Trailer Life RV Campground Finder Pahaska Our Community 12 08-03-2002 08:45 AM
