Old 02-21-2007, 07:29 AM   #1
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
Question Digital TV Antennas
My moho has an satellite dish/ antenna that, since I don't use the satellite, I was going to replace it with the original delta antenna. No luck finding a delta. Now I read that with digital TV, a whole new line of antennas will be offered designed to receive digital tv?
Anyone have information on these "new" antennas?
Pop Rivet is offline   Reply With Quote
Old 02-21-2007, 08:34 AM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Sorry David, I haven't seen anything yet. Since the normal broadcasting over the airwaves is to end in '08 I'm not sure what everyone is going to be doing. From what I have gathered from other forums is that the antenna you and I have is going to be fine, we will need to add a digital receiver or decoding box.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-21-2007, 08:59 AM   #3
Dover's Avatar
2006 25' Classic
Livingston , Terry
I recently purchased a Winegard Digital Reciever. It uses the existing antenna on your rig to receive the signal which is then broadcast on your TV in a digitial (many HD) format. Camping World has this item for 189.00 and an informative viedo to view before you spend any money.
Dover is offline   Reply With Quote
Old 02-21-2007, 09:13 AM   #4
Pop Rivet's Avatar
Altoona , Georgia
So Terry, Whats your assessment of the receiver?
Old 02-21-2007, 09:32 AM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
This seems to suggest the antenna stays the same. It's a good FAQ section on broader aspects of the subject in any case. OVER-THE-AIR DIGITAL TELEVISION RECEPTION FAQ: New to OTA? Start here! - AVS Forum
I browse AVSForum now and then -- just won't look at their traffic numbers. And we think we're awesome hitting 20,000 members...
5 meter Langford Nahanni
Old 02-21-2007, 09:48 AM   #6
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Off air DigitalTV is broadcast in the same part of the spectrum as analog. I don't think there is a need for a special type of ant, as others have suggested.
www.nesa.org
Air No. 6427
Old 02-21-2007, 10:17 AM   #7
Would it really be necessary to purchase an RV (Winegard) digital receiver? At least there is time to look before analog disappears or digital gets to all markets.
Old 02-21-2007, 10:57 AM   #8
2005 22' Safari
1960 24' Tradewind
Bob-
You have really good point there! Why worry about it now if you don't have too and, let everyone else buy them now and later on when the price goes down decide it you need it. To be honest, if we are boondocking, we don't have the power to spare to watch TV nor the time too. If we find ourselves at a campground 80% of the time they have free cable. So why bother at all with the digital? Don't we go camping to get away from it?
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 02-21-2007, 11:20 AM   #9
Pop Rivet's Avatar
Altoona , Georgia
Thanks Bob, That is a good link full of information.
Old 02-21-2007, 12:23 PM   #10
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Nothing special about antennas for digital signals.The same antenna you have been using all along will work just fine. It's just marketing hype.
You do however need a television receiver with an "ATSC" tuner. Analog tuners are "NTSC". I see a lot of people buying old stock NTSC "HD Capable" analog sets, thinking they are getting a deal because they are going so cheap now. You MUST have an ATSC tuner to receive HD and digital signals off air. Most if not all TV stations are broadcasting in both formats.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-21-2007, 02:05 PM   #11
Pop Rivet's Avatar
Altoona , Georgia
Ok - I use a laptop computer with a tv tuner card to get tv in the rv. I just looked and the card is for ntsc. Sometime I will have to get a tuner card for atsc and I'll be all set. I thought I got a very good deal on the tuner card when I bought it. Gotta be careful when buying tv stuff for the next couple years.
Old 02-21-2007, 02:23 PM   #12
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Try HDRV Antenna's in Calif...
The digital and HD signals are in a different (higher) frequency band than existing analog channels (VHF and UHF). Those channels are greedily coveted by other industries, and FCC has decreed they'll be shut down and given to mobile data companies right after Super Bowl in 2009 (Isn't politics wonderful...). FCC kept the $$ from auctioning off the frequencies...
They (the government and industry) will make several million discount coupons available in late 2008 to buy so-called ATSC tuners for older TV's that don't have digital tuning capabilities, as prices on tuners come down.
HD and Digital TV work well off newer over the air antenna's, though older smaller flat-screen TV's (like ours in Trailer..) will need one of the new tuners. We are enjoying all local stations in SF area on two HD TV's fed by roof antenna. No cable, no satellite, no monthly fees...We found Daryl Bassard of HDRV Antenna's in Stockton, CA, and he has developed line of RV antenna's designed for digital signals. They're more of flat plate than bars, and will easily fit onto existing Winegard-type retracting antenna structure.
He's at (209) 475-0703 or Welcome to HDRV Antennas Good guy, sells kits you can install or have installed, or will do himself, if you're on west coast...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 02-21-2007, 02:29 PM   #13
2005 22' Safari
1960 24' Tradewind
OK so we get you know what again by the technology changing faster than we can pay off the last A/V purchase. I'm going back to watching cave paintings!
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 02-21-2007, 02:37 PM   #14
1988 25' Excella
Images: 13
HD/Digital Antenna is $80...
I should have included the pricing.. The "Aluminum" model to match an Airstream is $79.95... If TV has ATSC receiver built in, no further expense, and no monthly fees or subscriptions, and no additional receiver to buy. If TV is an old one, without the new digital "tuner", then a tuner is supposed to cost less than $30, and coupons may make them much less expensive...
For those who travel with and use satellite receivers and dishes, going High Def will be between you and your satellite service... The ATSC receiver card for a laptop will be a great option connected to upgraded trailer antenna in a year or so...
Or, you could leave the trailer and watch sunsets, stars, local scenery or campfire, if video coverage is not good...
John
Condoluminum
Digital Thermostat jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 27 12-28-2009 03:20 PM
Digital Imaging Woes COArgosy78 Our Community 27 07-21-2003 10:09 AM
Antenna's igor Our Community 5 03-21-2003 09:57 AM
digital clock sovereign General Appliance Topics 3 08-06-2002 11:21 PM
a/c theromstat sudden impact Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-09-2002 06:04 PM
