02-21-2007, 07:29 AM
2017 27' Flying Cloud
Altoona
Digital TV Antennas
My moho has an satellite dish/ antenna that, since I don't use the satellite, I was going to replace it with the original delta antenna. No luck finding a delta. Now I read that with digital TV, a whole new line of antennas will be offered designed to receive digital tv?
Anyone have information on these "new" antennas?
02-21-2007, 08:34 AM
Always Airstreaming!
2005 22' Safari
1960 24' Tradewind
Anytown
, Connecticut
Sorry David, I haven't seen anything yet. Since the normal broadcasting over the airwaves is to end in '08 I'm not sure what everyone is going to be doing. From what I have gathered from other forums is that the antenna you and I have is going to be fine, we will need to add a digital receiver or decoding box.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
02-21-2007, 08:59 AM
2006 25' Classic
Livingston
, Terry
I recently purchased a Winegard Digital Reciever. It uses the existing antenna on your rig to receive the signal which is then broadcast on your TV in a digitial (many HD) format. Camping World has this item for 189.00 and an informative viedo to view before you spend any money.
02-21-2007, 09:13 AM
Altoona
So Terry, Whats your assessment of the receiver?
02-21-2007, 09:32 AM
St. Cloud
This seems to suggest the antenna stays the same. It's a good FAQ section on broader aspects of the subject in any case. OVER-THE-AIR DIGITAL TELEVISION RECEPTION FAQ: New to OTA? Start here! - AVS Forum
I browse AVSForum now and then -- just won't look at their traffic numbers. And we think we're awesome hitting 20,000 members...
02-21-2007, 09:48 AM
Remember, Safety Third
Catfish Corners
, Georgia
Off air DigitalTV is broadcast in the same part of the spectrum as analog. I don't think there is a need for a special type of ant, as others have suggested.
02-21-2007, 10:17 AM
St. Cloud
Would it really be necessary to purchase an RV (Winegard) digital receiver? At least there is time to look before analog disappears or digital gets to all markets.
02-21-2007, 10:57 AM
2005 22' Safari
1960 24' Tradewind
Anytown
, Connecticut
Bob-
You have really good point there! Why worry about it now if you don't have too and, let everyone else buy them now and later on when the price goes down decide it you need it. To be honest, if we are boondocking, we don't have the power to spare to watch TV nor the time too. If we find ourselves at a campground 80% of the time they have free cable. So why bother at all with the digital? Don't we go camping to get away from it?
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
02-21-2007, 11:20 AM
Altoona
Originally Posted by Canoe stream
Thanks Bob, That is a good link full of information.
02-21-2007, 12:23 PM
Moderator Emeritus
1972 31' Sovereign
High Springs
Nothing special about antennas for digital signals.The same antenna you have been using all along will work just fine. It's just marketing hype.
You do however need a television receiver with an "ATSC" tuner. Analog tuners are "NTSC". I see a lot of people buying old stock NTSC "HD Capable" analog sets, thinking they are getting a deal because they are going so cheap now. You MUST have an ATSC tuner to receive HD and digital signals off air. Most if not all TV stations are broadcasting in both formats.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
02-21-2007, 02:05 PM
Altoona
Ok - I use a laptop computer with a tv tuner card to get tv in the rv. I just looked and the card is for ntsc. Sometime I will have to get a tuner card for atsc and I'll be all set. I thought I got a very good deal on the tuner card when I bought it. Gotta be careful when buying tv stuff for the next couple years.
02-21-2007, 02:23 PM
2016 25' Flying Cloud
Sunnyvale
Try HDRV Antenna's in Calif...
The digital and HD signals are in a different (higher) frequency band than existing analog channels (VHF and UHF). Those channels are greedily coveted by other industries, and FCC has decreed they'll be shut down and given to mobile data companies right after Super Bowl in 2009 (Isn't politics wonderful...). FCC kept the $$ from auctioning off the frequencies...
They (the government and industry) will make several million discount coupons available in late 2008 to buy so-called ATSC tuners for older TV's that don't have digital tuning capabilities, as prices on tuners come down.
HD and Digital TV work well off newer over the air antenna's, though older smaller flat-screen TV's (like ours in Trailer..) will need one of the new tuners. We are enjoying all local stations in SF area on two HD TV's fed by roof antenna. No cable, no satellite, no monthly fees...We found Daryl Bassard of HDRV Antenna's in Stockton, CA, and he has developed line of RV antenna's designed for digital signals. They're more of flat plate than bars, and will easily fit onto existing Winegard-type retracting antenna structure.
He's at (209) 475-0703 or Welcome to HDRV Antennas Good guy, sells kits you can install or have installed, or will do himself, if you're on west coast...
John McG
Condoluminum
02-21-2007, 02:29 PM
2005 22' Safari
1960 24' Tradewind
Anytown
, Connecticut
OK so we get you know what again by the technology changing faster than we can pay off the last A/V purchase. I'm going back to watching cave paintings!
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
02-21-2007, 02:37 PM
Sunnyvale
HD/Digital Antenna is $80...
I should have included the pricing.. The "Aluminum" model to match an Airstream is $79.95... If TV has ATSC receiver built in, no further expense, and no monthly fees or subscriptions, and no additional receiver to buy. If TV is an old one, without the new digital "tuner", then a tuner is supposed to cost less than $30, and coupons may make them much less expensive...
For those who travel with and use satellite receivers and dishes, going High Def will be between you and your satellite service... The ATSC receiver card for a laptop will be a great option connected to upgraded trailer antenna in a year or so...
Or, you could leave the trailer and watch sunsets, stars, local scenery or campfire, if video coverage is not good...
John
Condoluminum
02-21-2007, 06:23 PM
Catfish Corners
, Georgia
I have a freq chart at work that shows both the old (anolog) and new (HD) bands at work (they are right next to each other). I'll try to see if I can post some it here tomeorrow (if I have time). There really should be no need to puchase a new antenna to watch HDTV. It's mostly sales hype from marketing companies. Receivers are a completely different story.
02-21-2007, 06:43 PM
More than one rivet loose
Los Alamos
, New Mexico
David,
The winguard batwing antenna (currnetly installed on AS) works just fine for both Analog and digital. They are in the same frequency spectrum.
If you by a new HDTV make sure it has among other things a ATSC and NTSC tuners.
Michelle TAC MT-0
Sarah, Snowball
02-21-2007, 08:44 PM
Round on both ends
1979 31' Excella 500
1975 28' Argosy 28
Rutledge
, Georgia
Thanks, John. I have been religiously opposed to amping up a basic dipole since I've gotten the Airstream, so I regard the batwing with some disdain. The old style, sort of complicated, Skyliner on my Argosy is such a better antenna. I just ordered the HDRV antenna to cram down on the batwing pole.
I have one of the cheap "Enhanced resolution" Sanyos mounted on the wall next to the fridge. With this antenna and a (hopefully) cheap converter, I hope to pick up some of the Atlanta stations that have been a STRUGGLE for the batwing.
Oddly enough, at home I don't have cable or a satellite, but I do have DSL. Most of what I watch is online, from iTunes, from Blockbuster (online ordering AND in store), and from my small DVD collection. Recently I've started watching scififreetv.com online, too. I only takes about 30 kbs of the DSL connection, and it's fine in a small window of my PC.
I also have a Media Center PC that I'm using as a work computer, and it's not hooked up to cable OR an antenna now. I'm using it to play my XM Roady II through.
I'll let y'all know if installing the HDRV antenna on the Winegard's mast is any great trouble. (Just have to add it into the list of OTHER repairs and upgrades I need to do to get it ready to hit the road this spring.)
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
02-21-2007, 09:31 PM
1965 22' Safari
Shelton
, Pacific Northwest
Hey David,
Never heard of a tv tuner card for my laptop. Does it just pick up what you would get with an antanne in a local area or do you have to subscribe to a service? Was it spendy?
Tammy
02-22-2007, 01:35 AM
Altoona
Originally Posted by tntssafari
Hey David,
Tammy
Hi Tammy - Do a google search on TV tuner card and you will see what it is. They are just small external tv tuners that plug into a USB slot. Most come with a remote control. The one that just get analog signals are pretty cheap now($40 - $50 ) and the ones that get both NTSC and ATSC are more pricey ($100 - $200 ). I'm certainly no expert in this area and you should see more posts with better information. You can get them at places like Circuit City. Welcome to the forum.
02-23-2007, 09:12 PM
1965 22' Safari
Shelton
, Pacific Northwest
Thanks for the information David. Looks like a good option since the laptop already goes everywhere I do.
Tammy
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Digital Thermostat
jcanavera |
Furnaces, Heaters, Fireplaces & Air Conditioning |
27 |
12-28-2009 03:20 PM |
Digital Imaging Woes
COArgosy78 |
Our Community |
27 |
07-21-2003 10:09 AM |
Antenna's
igor |
Our Community |
5 |
03-21-2003 09:57 AM |
digital clock
sovereign |
General Appliance Topics |
3 |
08-06-2002 11:21 PM |
a/c theromstat
sudden impact |
2 |
06-09-2002 06:04 PM |
