Old 02-12-2008, 06:39 PM   #15
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
FWIW I won a 16.5" LCD screen TV with digital tuner at my last company picnic It is slated for installation in my Airstream...one of these days I did, however check it out hooked up to my 20+ year old rotator home antenna. Great picture and great pickup on the number of stations over the older analog set in the house. Don't need to "upgrade" any antennas unless you are using a coat hanger and tinfoil...then it might be advantageous
Aaron
WBCCI #XXXX AIR #2495
Old 02-12-2008, 07:02 PM   #16
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
You mean I have to upgrade?
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-12-2008, 07:09 PM   #17
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Digital Signal
Tha digital signals are being broadcast by most stations, especially in larger cities.
We installed a 20" Vizio HD in our 1965 Caravel a year ago. The only problem is, I should have put in a bigger set. The old antenna, the folding one outside on the left front corner, with the little handle inside to turn it, works just fine. If your antenna has a UHF loop built in, which most all have since the 60s, it will pick up digital broadcast just fine.
As far as a box to convert your old TV to play digital, that's up to you.....But...after seeing HD on a new, flat, bright screen, I don't have an old "tube" TV I want to spend the converter money to watch.
Does the saying "throwing good money after bad" ring a bell?
Range of Batwing??? Sovereign86 Audio, Video & TV 8 08-22-2007 08:46 PM
Batwing Antenna Stand-Off jdalrymple Audio, Video & TV 3 06-15-2007 02:10 PM
Digital TV jcanavera Audio, Video & TV 3 02-02-2007 10:51 AM
Batwing aerial upgrade gloran Audio, Video & TV 0 01-27-2007 08:04 PM
batwing antenna for 68 GT mimibeth Audio, Video & TV 0 07-22-2006 12:58 PM
