Old 08-18-2014, 10:20 AM   #15
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
In our '09, there are cable outlets under the dinette and in the state room, so that accounts for the split of the signal out of the wall plate.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 08-23-2014, 06:04 PM   #16
2008 27' Safari FB SE
Delta , BC
Does anyone know where the set 2 TV hookup off the TV booster terminates? The main TV goes off the front of the booster face plate and the bedroom TV is set 1 on the back of the booster faceplate but where does set 2 go?
bugman3 is offline   Reply With Quote
Old 08-23-2014, 07:26 PM   #17
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
There are two jacks in the bedroom of my 2001 Safari 25 Twin. One at the rear curbside of center at the head of the bed and one near the TV shelf at the foot of the curbside bed. Beats me how you would ever use the center rear jack. If I remember correctly, the wire off the back of the LR baseplate goes to the BR rear wall box where a splitter routes to the wall jack there and to the jack at the foot of the bed.
Are you sure the other wire is for another set? In my trailer the other wire in the LR is the input from the exterior cable TV jack. My PO had rewired the LR box with another splitter to use the cable hookup wire as another output to put a TV outside.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 08-23-2014, 07:30 PM   #18
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Is there a cable connected to it?
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 08-23-2014, 08:32 PM   #19
Does it look like this?
http://www.winegard.com/kbase/upload/2451487.pdf
S/OS #004
Old 08-24-2014, 07:34 AM   #20
Delta , BC
No, there is a connection to a splitter off the back of the tv booster and then there are 2 labelled connections, set 1 and set 2. Beats me where set 2 goes.
Old 08-24-2014, 10:15 AM   #21
Look in all your exterior compartments and wherever your cable TV input is. Someone may have added an outside connection.
Al
S/OS #004
Old 08-24-2014, 10:30 AM   #22
I looked at the wiring harness diagram for the older 27 as yours is not published. It looks like there are two cables to the bedroom area. If you only have one box, there may be another cable in it. But as I said there are two tv connections in my BR. Curbside plate near foot of twin bed has 12 cig lighter socket and TV cable. Rear wall near curbside bed head has phone and TV cable.
Al
S/OS #004
Old 09-21-2014, 12:23 PM   #23
2014 28' International
San Jose , California
Air Cable selection
Originally Posted by Protagonist View Post
Input from the antenna or cable is ALL of the channels, all of the time. You don't pick WHICH channel until you get to the channel selector in the television or recorder.
Without actually seeing the setup, I can only think of two reasons why your setup could be working (not working) the way it is:
1 - You have an A/B switch instead of a splitter, so selecting one television turns off the signal to the other. But if that was the case, you'd have to manually select the A circuit or B circuit, and I'm sure you would know if you're doing that.
2 - You have a weak signal coming into the splitter, so it's even weaker coming out. But if that was the case, it's more likely that when you turned on the second television you'd lose signal to both because the signal is stupid; it can't pick which television it prefers, and the signal would be split equally between them when both televisions are on.
I'm sure there are other reasons; those are just the only ones I can think of. Which probably means I'm just as stupid as the electricity is.
Hi,
Quick question for you, I seem to have a similar problem with our tv. We just got our first AS, A 28 intl signature, however at first camping evening we tried to watch some tv from the park cable hookup and while we tried to select the cable option from the menu (air-cable) all we got was a bunch of chanels scrambled with white snow. Although the manager of the campsite tried to help us all we got was a bunch of scrambled images. However by changing the selector option to air, we where able to see some chanels. Some said air from the guide others just have the stations codes, but keeping the tv on cable we got nothing. Any ideas? Been a brand new rig I was expecting to have an automatic feed option... Will be very appreciative of any assistance. BTW , couldn't find any info about manual splits or switches to change in the manuals.
Flyingsilver is offline   Reply With Quote
Old 09-21-2014, 12:36 PM   #24
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Originally Posted by Flyingsilver View Post
Hi,
I had the same problem at a CG with cable last week. Then I tried to simply turn off the antennae booster (on our AS it's the small black button on the plate behind the main TV with the antennae cable) and "poof" the cable channels came in clear as day!
From this experience, I believe that the booster must be "on" for over the air channels but "off" for cable TV. Also, the booster places a small load on your batteries so it is probably a good idea to turn off when not in use.
Bob Martel
WBCCI# 5766
Old 09-22-2014, 09:09 AM   #25
The booster switch does double duty. In addition to turning the preamp in the antenna on and off, it also switches the feed to all TVs between the cable input and the antenna. Booster OFF for cable, ON for antenna.
Al
S/OS #004
Old 09-22-2014, 09:58 AM   #26
Chelsea , Michigan
Images: 12
Al
I checked the owner's manual (I know, I know ) and it confirms that the booster should be on for over-the-air and off for cable.
Bob Martel
WBCCI# 5766
'64 Overlander brake and turn signal issues 57BB Lights - Interior & Exterior 4 08-24-2012 10:21 AM
NEWB, Right turn signal and brakes come on?!? steven2themax Brakes & Brake Controllers 11 08-10-2010 12:01 AM
Brake and Turn Signal Problems with Mercedes dougderocker Lights - Interior & Exterior 12 11-09-2008 02:29 PM
Different sized tires front and rear AgPnut Tires 14 09-09-2008 03:23 PM
Different Looks on Different Computers COArgosy78 Forum Admin, News and Member Account Info 3 09-20-2003 02:38 PM
