Old 04-25-2016, 04:16 PM   #1
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Dang It - Antenna Woes!!
Dang It!!! Antenna Woes
Dang it.....I made a very stupid mistake yesterday. I was backing the Airstream into it's storage shelter and didn't pay attention to see that the door had slid down a bit on the storage shelter. It snagged the round tv antenna and snapped it off. It's the Omni Directional Antenna. It looks like there is a crack in the stem part and it's still connected to the cable. I was so mad at myself that I just quit for the day and went inside and pouted.
Anyway, I don't know if I can repair and re-attach the stem to whatever it attaches to or if I have to take it in for repairs or if I can put a new one up there myself.
Any input/advice is welcome
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 04-25-2016, 04:21 PM   #2
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Probably should replace it. Any RV shop or Camping World if one in in your area. Don't be upset, I've seen much worse on new RVs.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 04-25-2016, 04:29 PM   #3
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
What a bummer! Given the integral way the internal pieces & components are assembled in the casing, you most likely need to replace the whole mast. It is not hard or even difficult (if you are handy) and it may be cheaper to source a whole new unit via the net. Be sure to use sealant and you should be done within the hour if there is no damage to the metal on the roof.
http://www.amazon.com/KING-OA8200-An.../dp/B004VF48YO
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 04-25-2016, 05:55 PM   #4
1999 30' Excella 1000
small town , Maryland
I thought I was the only one...I'm normal Almost the same. Parking garage...tall truck.
streaminwild is offline   Reply With Quote
Old 04-26-2016, 11:27 AM   #5
Parker , williamdcrockett
I did that last year and broke one square tube on the mask. I took the Antenna down, disassembled it and took the one square tube that was broken Lowes. I found the same size square tube, bought it, drilled holes in it to match the one I broke and installed it. It works great.
wcrockett is offline   Reply With Quote
Old 04-26-2016, 11:34 AM   #6
Great advice.....thanks!
I wasn't able to get up on top and take pictures last evening. Am going to try again this evening. Meanwhile, I checked with Winegard and they can sell me just the top round part if that is all I end up needing.
Old 04-27-2016, 04:40 AM   #7
1969 27' Overlander
Kimmell , Indiana
I have done business with these guys. Very happy.
solidsignal.com
Hoosierdaddy is offline   Reply With Quote
Old 04-27-2016, 05:36 AM   #8
I got the ladder out and got up on the roof last night to assess the damage. Only the plastic stem on the actual antenna is cracked. The metal base is fine. I am able to order the antenna part without the base for around $54 and will do the repairs when the part arrives. I will definitely be more careful in the future!
Old 04-27-2016, 04:42 PM   #9
2007 22' International CCD
Definitely good news there!
KE4GNK/AE
Old 04-27-2016, 04:47 PM   #10
Long Island , New York
Good news Steve!
Now about being careful on ladders . . .
OTRA15 is online now   Reply With Quote
Old 04-27-2016, 05:20 PM   #11
Boy....isn't that the truth.....with my luck lately I will end up intertwined in a ladder wearing a Winegard Antenna Hat!!
Old 05-10-2016, 05:43 AM   #12
From later posts it appears you survived the high-wire act? How is the antenna?
Peter
Old 05-11-2016, 04:44 AM   #13
It was easier than I thought to get up on the roof. Stayed on the rivet lines. I got the old one off, connected the cable for the new one and got it installed to the first scribe line on the mast. For the life of me, I am not able to get it to snap down to the second scribe line as per the instructions. I called the manufacturer and they said I may need to take it in or have a mobile service come out. I can't pull the new antenna off or get it to snap down to the scribe line. I will try again one evening this week. I had run out of time and daylight on the first try.
Old 05-11-2016, 02:29 PM   #14
richinny's Avatar
2011 34' Classic
you might be able to work on the mast from just the ladder by lowering the antenna so it hangs over the side of the trailer.
Ricky
Ding dang 'ol axle cojer Axles 25 03-23-2011 04:51 PM
dang it ... no furnace for me! funkill Furnaces, Heaters, Fireplaces & Air Conditioning 5 01-01-2011 08:39 AM
Well it finally happened...DANG IT!!!!! THEPILL Our Community 9 11-05-2010 11:54 PM
Dang this part of the thread seems dead THEPILL All Argosy Trailers 7 01-10-2010 03:21 PM
dang it! lost a hubcap flitzwhopper General Repair Forum 10 07-11-2009 07:25 PM
