Old 02-02-2014, 07:08 PM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Crank up antenna problem?
We have a 2001 Safari with the crank up antenna. When cranking it up the mast goes past vertical. All the pictures I have seen of deployed antennas show the mast vertical. I don't see anything in the manual about a stop or adjustment. What does your antenna do?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 02-02-2014, 07:25 PM   #2
SteveH's Avatar
Common Sense , Texas
I think they all go up a little past vertical.
Regards,
Steve
Old 02-03-2014, 08:40 AM   #3
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
By going past vertical my thinking is that it gives it a greater circle to rotate within. Perhaps allowing it to grab a broader range of channels. I'm to techie but that's just my thinking.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 02-03-2014, 09:18 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
As an engineer, I think not. If it rotates 360 horizontally anyway, then cranking it vertically to 95 is the same as cranking it vertically to 85.
But, if you were to crank it open to 89, almost but not quite vertical, then its own weight will make it try to sag down to the retracted position, putting a strain on the operating mechanism that has to hold it up. If you crank it open to 91, just a little past vertical, then if it starts to sag, it will sag against the stops and stay open, with no strain on the operating mechanism. In other words, the extra little bit of over-travel is a hold-open device.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-03-2014, 09:58 AM   #5
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Is it really going past vertical or does it look that way? Mine and most of the ones I've see are mounted considerably off center on the roof so that when retracted it doesn't interfere with the skylights and A/C. That puts it on the curved part of the roof and when extended looks like it's listing to port.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 02-03-2014, 10:37 PM   #6
Thanks everyone!
It is going past vertical. When cranking it up it is oriented in line with the length of the trailer. Viewing it from the side, it is going about 5 degrees past vertical. I got up on a ladder today and took a look at the mechanism. It appears it is designed to work that way. Mine is mounted to the curb side at the front of the trailer. The front of the two mast bars hits a stop formed by the base to end travel. So I'm going to conclude that it is supposed to go past vertical as SteveH has suggested and stop worrying about it.
Al
S/OS #004
Replace old TV antenna with new one perryg114 Audio, Video & TV 15 09-06-2017 12:02 PM
Furnace Problem NOAZRK2690 Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-10-2014 08:34 AM
Mattress Moisture Problem? palmer51 Winterizing, Storage, Carports & Covers 41 12-01-2012 12:17 AM
What's the worst problem you ran into? Eaglemate On The Road... 16 10-29-2011 05:32 AM
Safari 2005 Window Crank Failure neil.ervin Windows & Screens 3 10-24-2011 06:37 AM
