Old 04-11-2009, 01:25 PM   #1
The handy accountant
pageclot's Avatar
1976 27' Overlander
Scarborough , Ontario
Images: 21
Converting original motorola 8 track unit to something modern - questions
We have a 27' International, which came with the original Motorola 8 track, am/fm radio attached to a drop down unit next to the door.
I would like to replace this with something modern.
The Motorola unit has:
- an antenna plug (which I've found a counterpart for, on the modern unit, hooray).
- 2 flat speaker connectors. The modern unit has the standard red and white round speaker connectors.
- Umpteen wires, in many colours, coming off one of the knobs
- Presumably, the Motorola will run on either 120 or 12 v, because I had to shut off the main breaker, and pull the 50 amp fuse to get it to stop working. The modern unit seems to be designed for only 12 volt usage.
The modern unit seems designed to plug into a receptacle, with about 12 or 14 gold spikes in the upper right corner.
I'm going to take pictures, and then go back to Canadian Tire where I bought the modern unit, to see if they have any ideas how to update it.
In the meantime, is there a standard wiring diagram for this motorola unit around somewhere? The users manual that came with the radio was somewhat less than useful.
Any help would be appreciated.
pageclot is offline   Reply With Quote
Old 04-11-2009, 01:54 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Look into aftermarket wall mounted audio for RVs. I got a Audiovox and it fits nicely into the old hole.
Old 04-11-2009, 03:20 PM   #3
1976 25' Caravanner
Campton , New Hampshire
I don't have the ability to scan right now , the diagram is in the service manual , if you can get one it will be handy for many other things. I'll try to discribe the wiring .
Coming out of the radio/8 track
1- ground 12v-
2- fused 12v+
3- antena
4- plug red/black wire
5- plug blu/black wire ( 4 & 5 are left and right output to speakers or fader)
6-plug 3 wire , remote on/off switch , might not be able to use with new unit
Coming out of fader
orange/black = curbside rear speaker
red/black = curbside front spesker
gray/black = roadside rear speaker
blue/black = roadside front speaker
BTW , the old and new units will be 12v only
Good luck
ticki2 is offline   Reply With Quote
Old 04-11-2009, 03:29 PM   #4
pageclot's Avatar
1976 27' Overlander
Images: 21
You're awesome, ticki2!
This helps a lot. The colours on the new unit will not match, but I can figure it out from here, I hope.
I have the owners manual from the 76, but not the service manual.
Old 04-12-2009, 09:26 AM   #5
pageclot's Avatar
1976 27' Overlander
Images: 21
Success! I hooked up all the wires, without any left over, (hooking up the yellow wire from the new radio to the 12 v wire from the airstream meant that the faceplate gets power, and works), turned on the radio, and heard a cut from Sgt. Pepper.
Now I just have to fasten the new radio to the drop down door, figure out how to get the door to drop open just so far, and then clean up the bits of wire.
Thanks to all.
Old 04-12-2009, 10:39 AM   #6
1976 25' Caravanner
Don't ya just love it when that happens . Good job
Old 04-12-2009, 10:47 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
A short piece of decorative chain and two loops would serve.
Old 04-12-2009, 10:53 AM   #8
1976 25' Tradewind
Erie , Pennsylvania
I modiefied the original box to fit a new system. I also changed out the speakers. The whole change costs about $150. It was important that I bought a stereo that had an aux jack for my IPOD. I will take some pictures and post.
rollingbubel is offline   Reply With Quote
Old 04-12-2009, 11:30 AM   #9
Well Preserved
1993 21' Sovereign
There are also car stereos that have a USB port for connecting and charging the iPod. The ones I've seen have been about $150, and eliminate the need for figuring out how to keep the iPod charged.
Old 04-12-2009, 04:51 PM   #10
pageclot's Avatar
1976 27' Overlander
Images: 21
I think I have changed the centre of gravity of the door, now that I've replaced the 10 pound motorola with a 3 pound jvc. The door seems to pop open a lot easier. I think I might use your suggestion of the chain and two loops, but supplement it with a magnet to keep the door shut when I want it to stay shut.
Old 04-12-2009, 06:18 PM   #11
Ottawa , ON
For those with no input for iPod etc., there are accessory units designed to plug into 12V sockets (like cigarette lighter sockets) into which the iPos plugs, that broadcast the iPod signal by FM.
Neat, simple, and cheap.
Old 04-12-2009, 06:25 PM   #12
Well Preserved
1993 21' Sovereign
My wife and I both have this for our iPods in our vehicles, and there is no reason it won't work in the trailer as well. If you are looking to replace your 8 track with a cd player, that is the time to get the USB radio. It's certainly not a reason to go out spending and updating just for that alone.
Here is a link to the radio, and a link for the FM iPod adapter:
Radio:
http://sewelldirect.com/vr3-cd-playe...utm_medium=cse
FM adapter:
http://www.amazon.com/Kensington-Dig.../dp/B0007XXHNW
Removing a radio/8-track unit for repair or replacement lbf78SvgnInt31 1974 - 1979 Sovereign 9 11-30-2012 04:08 PM
Motorola 8 Track Mr. Decent Audio, Video & TV 13 09-03-2009 08:02 PM
IKEA window track - alternate to original? funkill Upholstery, Blinds, Walls & Interior Finishes 6 03-19-2009 08:47 AM
converting original frig joqin Refrigerators 4 07-01-2007 10:28 AM
Motorola Radio + 8 track player m. Clarke All Argosy Trailers 2 03-19-2004 10:48 PM
