Can't get antenna to work - is there a splitter and if so where would it be. I see under table outlet and cable (or antenna) hookup with red light on.?? I have not been to a park yet with cable so not sure if that works but I can't get antenna to work. Could use some suggestions. Thanks
Hi - not sure it's this way in your model but in mine, there is a button for the antenna when you want to use it for signal and you switch the button when using cable. Also, have you set up the TV to receive the channels your antenna is picking up? It should be somewhere in your TV setup menu. Hopefully that's of some help. If not - some people who really know what they're doing will chime in soon!
