Old 02-11-2015, 12:06 PM   #1
2007 27' Classic FB
Bellingham , Washington
Coax connections
When I connect to coax cable tv at exterior of my 2007 27' FB Classic, there's no signal. When I connect directly to the television, it gets a strong signal. It seems the breakdown is in the wall behind the refrigerator. Any suggestions on how to troubleshoot? If the problem is behind the ref, will I have to pull it to fix? Anyone out there have this problem?
vhaalen is offline   Reply With Quote
Old 02-11-2015, 02:09 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Are you pressing the pushbutton on the TV outlet plate to turn off the preamp? That switches the internal distribution from the antenna to the cable input. The green LED for the preamp should be off.
You will also have to re-scan and set the scan function in the TV for cable channels.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 02-11-2015, 04:59 PM   #3
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
BTW if you have more then one TV location be sure to check both for the amp button in case you don't find it on the first location.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 02-12-2015, 12:00 AM   #4
2007 27' Classic FB
There are 3 coax connections in our coach but only one has the amp button. I know to turn that off when connecting with cable, but still no signal. Is there a way to check continuity of the coax routing? I'm still thinking there's a bad connection somewhere between the exterior and interior (aka behind the refer).
Old 02-13-2015, 11:16 AM   #5
Does your trailer have satellite wiring? If so there is probably a jack plate with two coax connectors on it and there should be a short jumper between the jacks.
If that is all normal, then in my experience, it is more likely that someone has reconfigured the wiring. The coax from the outside should run directly to the panel with the switch and LED. If you don't have a manual for the antenna, and assuming you have the original antenna, Google Winegard Sensar to find one. It has a diagram of which connector is which on the circuit board. If I remember correctly it is the jack in the center of the circuit board.
My trailer had been rewired by placing an extra splitter in the wall behind the jack with the switch and connecting its input to the output of the switch that went to the other TVs in the trailer. The cable to the other TVs was on one output of the new splitter and the cable to the outside was on the other port of the splitter. This allowed the cable to be used to send a signal from the antenna to a TV outside the trailer instead of as a cable input.
The giveaway is that there is a splitter behind the switch panel and nothing connected to the center jack on the circuit board. The easiest thing to do is pull that switchplate and check the wiring behind it. You could also set the system to antenna and hook up a TV to the outside jack to see if it works. Less work than pulling the switchplate, but if that is the problem you will have to pull it to fix it.
Oh, put the trailer in storage mode or disconnect the battery before pulling the switchplate. It is very easy to short the 12 volts when pulling the plate and that will blow a fuse. Don't ask how I know....
Al
S/OS #004
Replace coax on 1997 34' Excella Aviator Audio, Video & TV 2 10-28-2011 08:35 AM
Cable TV/ Satellite Receiver Dual Coax Face Plate pwesterman 2008 Safari SE 2 11-14-2010 01:09 PM
2010 Int'l: Does cable coax go straight thru? or thru amp? amm3824 Audio, Video & TV 2 10-18-2010 08:32 PM
Antenna coax down refer vent. dsrtquest Audio, Video & TV 1 09-01-2003 03:24 PM
Outside Coax feed Krazykraut General Motorhome Topics 2 10-06-2002 05:39 PM
