Old 04-26-2012, 08:41 PM   #1
Frank&Mike's Avatar
2016 27' Flying Cloud
Georgetown , Texas
Coax Cable for Outside Cable Connection
I would like a cleaner look for the outside cable connection at campsites.
Is television coax cable only available in a straight-line configuration (like photo #1)?
Or is television coax cable available in a configuration like on phone headsets (like photo #2)?
I don't like how the traditional straight-line configuration looks all strung out when hooked up at the campsite. If it's available in something like what's on a phone headset I want to purchase it. Any ideas?
Frank&Mike is offline   Reply With Quote
Old 04-26-2012, 09:11 PM   #2
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
icocbw, but I don't think you'll find a coaxial RG-6 cable in a "spring-cord" version.
you might try some velcro straps to coil up and secure your excess cable length - Hook and Loop Fastener , Cable Ties, Computer Cable Organizers, Rubber Grommet, Velcro Cable Ties, Wire Wrap
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 04-26-2012, 09:12 PM   #3
Ottawa , ON
Any ideas?
None here.
Personally, I don't think you have a choice. Well, other than not connecting to the cable system...
Old 04-26-2012, 09:51 PM   #4
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
I've never seen any curled coaxial cable, but I have used this on 12 and 25 ft. runs without any appreciable signal loss.
Amazon.com: GE 23278 Ultra Thin Coaxial Video Cable (Black, 25 Feet): Electronics
I would imagine any flexible coaxial cable, in the form you mention, would have to have stranded center conductor, rather than the solid wire used in standard coax.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 04-27-2012, 07:15 AM   #5
knunut's Avatar
Chgo. N.W. Burb's , Illinois
You might find a "Right Angle" connector. Attach that to Trailer and cable into that ,it would make it look better.
knunut is offline   Reply With Quote
Old 04-27-2012, 08:11 AM   #6
2008 27' International CCD FB
Visalia , California
You can buy the right angle connectors at Best Buy or Radio Shack. This will run the cable straight down. I had to add one to the back of the TV I installed in the bedroom, I used a very close to the wall mount which allowed no room to connect the coaxial cable.
I like your idea of clean look, I'm off to buy the right angle connector for the outside connection today.
Chuck
ThreeFingers is offline   Reply With Quote
Old 05-28-2012, 08:15 PM   #7
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
Originally Posted by ThreeFingers View Post
You can buy the right angle connectors at Best Buy or Radio Shack. ...I like your idea of clean look, I'm off to buy the right angle connector for the outside connection today.
Chuck
The RAA cleans it up for us ...
2015 25' Eddie Bauer Int Sp Ed
2015 Chev Duramax 2500; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Old 12-17-2012, 08:16 AM   #8
xitjustice's Avatar
1994 28' Excella
Clearwater , Florida
My cable plugin goes near the power cord. If you lead the extra cord to where the extra power cord is stored, you may have your problem solved.
However, there may be 'inductive interference' with the signal (hope that's the right term for it). If there is no signal problem, you could even use garbage bag/twist/zip ties to follow the power cord.
If someone tries this, let us know if it works! Thanks.
xitjustice is offline   Reply With Quote
