Old 03-05-2017, 10:52 AM   #1
Coast to Coast
Two Peas's Avatar
2016 26' Flying Cloud
St. Augustine , Florida
Clarion speaker sound fluctuates
The sound from the right speakers (front & rear) fluctuates on both TV and radio - does not sound like a loose connection (static), but more of a drop in sound - then returns to normal sound. Thoughts? 2016 26U
Two Peas is offline   Reply With Quote
Old 03-05-2017, 12:11 PM   #2
2015 30' Classic
Pleasanton , California
It's likely that the problem is either:
1. A loose connection exterior to the amp, or
2. A faulty right-side channel in the amp.
Since you're covered, you should bring it back to the dealer and let them deal with it. If you're handy and you would like to save yourself a trip to the dealer, I'd double check the connections at the back of the amplifier.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 03-05-2017, 12:27 PM   #3
2018 28' Tommy Bahama
2017 23' Flying Cloud
2014 16' Sport
New York , New York
Images: 11
I'd probably just pull the unit real quick before going through the hassle of towing it back to the dealer. There is a little tool that came in the box that was in your airstream with the faceplate case. It looks like a little metal shim, use that to pull the radio and check the wires in the back.
If you don't see anything also pull down the speakers and make sure there is nothing shorting the terminals out, like a scrap of aluminum. You get the covers off the speakers by taking a small screwdriver or tool and popping the grill out (clarion) and then unscrew the speaker and it will drop down.
I had one that was buzzing and it was just a whole bunch of wood chips that fell down into the speaker. It's about a 5 minute job each speaker, far easier than towing back to the dealer.
mattskav is offline   Reply With Quote
How to remove Clarion speaker grills? khollister Audio, Video & TV 65 07-23-2017 12:16 PM
Clarion Sound System on Classic 2015 TonyGuyer 2011 - 2015 Classic (all lengths) 17 08-09-2015 03:43 PM
Shower temperature fluctuates BillyAir Plumbing - Systems & Fixtures 15 01-16-2015 05:13 PM
Speaker Switch & Speaker Replacement vswingfield Audio, Video & TV 17 10-01-2011 06:48 PM
TV sound from speaker system.... evanskl Audio, Video & TV 4 05-14-2009 07:29 AM
