Old 04-07-2018, 07:29 PM   #1
2017 25' International
Ladysmith , Wisconsin
Clarion M303
Can someone give me really detailed, "for dummies", button by button, instructions on how to delete a pairing from our radio? I can't find something detailed enough for us to actually figure out how to do it. Thanks for your help!
llanderson64 is offline   Reply With Quote
Old 04-07-2018, 08:38 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I ripped mine out and and replaced with a touch screen entertainment system but maybe these instructions for the M303 will help:
1. Turn on Bluetooth function of your mobilephone.
2. Enter mobile phone's Bluetooth setupmenu.3. Search for new Bluetooth devices.
4. Select M303 from the pairing list on themobile phone.
5. Enter "0000" as the password (Thepassword default setting is " 0000 ").
6. After pairing successfully, the unit willenter Bluetooth mode automatically, and"BLUETOOTH CONNECTED" will appear on the LCD.
wulfraat is offline   Reply With Quote
Old 04-08-2018, 08:40 AM   #3
Unforturnately, I am requesting help DELETING pairings. I know how to set them up.
Old 04-08-2018, 08:50 AM   #4
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
I found this, but haven't tried it. I hope it helps.
SELECT (BT mode)
This “SELECT” menu is intended to automatically paired by selecting a mobile phone was stored.
This unit can store three mobile phones. The mobile phone will be stored in paired order to the unit. The fourth mobile phone can not be stored. If you want to store a fourth mobile phone, please delete unwanted mobile phone from “DELETE” menu.
Rotate the [VOLUME] knob to choose the paired mobile phone name from the pairing list.
Press and hold the [VOLUME] knob to confirm.
DELETE (BT mode)
1. Rotate the [VOLUME] knob to choose
pairing list.
2. Press and hold the [VOLUME] knob to
confirm.
DISCONNECT (BT mode)
Disconnect currently connected mobilephone.
1. Rotate the [VOLUME] knob, mobile
phone displays are currently connected.
disconnect.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 04-09-2018, 08:06 AM   #5
I have found that too. My problem is I don't know how to get to BT mode.
Old 04-09-2018, 08:31 AM   #6
wulfraat's Avatar
Clarion M303
Hit the big SRC button on the left to get to Bluetooth mode.
Old 10-15-2018, 09:36 AM   #7
2017 27' Flying Cloud
Fort Worth , Texas
Hate this radio as it is not intuitive and I only use it every few months. I cannot access bluetooth from the SRC button. I only get two options....Tuner and Aux. I have M303 in my phone's bluetooth setting, but I can't get to the bluetooth menu of the Clarion???
billrector is offline   Reply With Quote
Old 10-15-2018, 09:46 AM   #8
Fort Worth , Texas
Never mind...got it. I had to "forget it" on my phone's bluetooth setting and it re-found the Clarion and connected. Then I had a bluetooth selection using the SRC button.
Old 12-25-2018, 12:46 AM   #9
2019 23' Flying Cloud
West Sacramento , California
I spent 40 minutes trying to pair this phone to the M303. Nothing. I absolutely HATE this radio. The last few times via the src button Bluetooth appeared without issue. Today nothing showed up no matter how many times I have turned on/off my phone or the radio and attempted pairing. My phone occasionally "finds" the radio but then...zilch. The radio will not play and one can't even get to the Bluetooth menu.
Menu button on the radio is defunct. Src gives me Aux/Tuner.
Any help getting to bluetooth would be appreciated.
Brandon T. is offline   Reply With Quote
Old 12-26-2018, 08:34 AM   #10
Fort Worth , Texas
I had this recently also. First make sure you are pairing with M303 in your Bluetooth setting. If that does not work, try removing M303 and add again. You will not see Bluetooth in the radio menu until you are paired.
Clarion M303 radio to lap top aux Projet2907 Electronics & Connectivity 3 05-22-2018 09:03 AM
Clarion M303 replacement Mgieselman Electronics & Connectivity 3 05-22-2017 03:49 PM
How to pair M303 to my iphone mcomeaux Electrical - Systems, Generators, Batteries & Solar 2 04-27-2016 08:13 AM
Binning the Clarion M502 Gsmblue Audio, Video & TV 9 04-07-2015 01:04 AM
Clarion, Pa. Autumn Leaf Festival 2014 pintoman Other Rallies & Events 1 09-13-2014 09:04 AM
