Old 06-09-2015, 03:42 PM   #1
1971 31' Sovereign
Indian Wells , California
Can't get the Skyliner to rotate.
I have a broken gear set so I'm tearing into the antenna. It seems locked up. I've removed the large pin with the C clip so I can lift it up. I also took out the roll pin and pulled the shaft out through the interior. I even drilled out the 2 rivets and took off the big C clip on the interior but it will not turn. Lots of PB Blaster and light taps with a hammer in both directions and it still won't budge.
Any ideas? I've read the docs posted on here and some threads so I'm stumped.
CraigCA is offline   Reply With Quote
Winegard Sensar won't swivel (rotate) cammur Audio, Video & TV 6 03-17-2015 10:27 PM
Hubcaps rotate over time / miles? WineStream Wheels, Hubs & Bearings 7 04-22-2010 11:37 AM
Braund Skyliner antenna amplifier needed. bmklawt Audio, Video & TV 21 02-16-2009 07:29 AM
Rotate tires? Boondocker Tires 10 02-17-2006 09:15 PM
