Old 06-21-2009, 10:22 PM   #1
2009 22' Interstate
Roaming , USA
Can the interior/bathroom wall hold two LCDs?
I currently have a 19" LCD mounted on the wall above the dinette (28' CCD) -- this is the "front" wall of the bathroom.
I want to replace the 19" with a 26", and also mount a 24" LCD on a long arm below the TV (basically to be able to pull it closer to the dinette to use as a monitor with a wireless keyboard/mouse attached to a mac mini)
Can the wall hold these two, if I use the airstream mounting plate? My alternative is to get a clamp-type monitor arm and put it in some ugly place, but that will get in the way. (total weight of the two units is about 37lbs)
ChromeNomad is offline   Reply With Quote
Old 06-21-2009, 10:31 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have seen bathroom walls come loose with nothing mounted on them; But two TVs at 37lbs mounted on the same wall would be too much in my opinion.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-22-2009, 05:13 PM   #3
Cstar's Avatar
2006 28' Safari SE
Columbus , Ohio
Images: 20
Two for One?
I would not permnantly mount one, let alone two. We have a 28' SE we mounted a 32" TV but take it down for travel. Check out the photos in my gallery for how we reinforced the bath wall.
As a side note. Our bathroom wall did come loose. We had it repaired at the factory. They said the wall repairs were needed because of improper installation and had nothing to do with our TV mounting.
Corky
Cstar is offline   Reply With Quote
Old 06-22-2009, 08:14 PM   #4
2009 22' Interstate
Roaming , USA
So much for that plan. Guess it's on to plan B..
thanks!
how to repair interior (vinyl?) bathroom wall? ray henton General Interior Topics 2 07-15-2012 11:55 PM
bathroom wall material durans54 Upholstery, Blinds, Walls & Interior Finishes 7 01-23-2007 06:05 AM
interior bathroom wall repair help needed! ray henton General Interior Topics 5 08-30-2006 08:00 PM
PO cut a hole in interior bathroom wall to fit the new toilet. Sregon 1967 Overlander 7 08-18-2006 09:30 AM
interior bathroom wall repair help needed! ray henton Cabinets, Counter Tops & Furnishings 2 08-13-2006 10:39 PM
