Old 11-12-2006, 12:54 AM   #1
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Can LCD Monitor/TV Take a Freeze?
Has anyone been leaving their LCD monitor in their unheated Airstream in freezing temperatures and below? We took ours out but my friend is leaving hers in. Are we being too cautious? I would rather it was there ready for use.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 11-12-2006, 06:42 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Curious question -- but worth asking!
http://hardware.mcse.ms/archive144-2005-10-247970.html
http://www.hdtvexpert.com/pages/flat_panel.htm
http://www.bikeforums.net/archive/in.../t-240672.html
These seem to say an LCD can be stored in cold but need to be at warmer temperatures to actually function. LCD displays in our cars, bike computers, and GPS are exposed to cold. I know that the LCD in my previous tow vehicle did not display below -10 degrees F. I don't know that I'd risk it with a more complex TV if it was easy to remove. Let somebody else do the experimenting -- and maybe we'll get answers from those that have. But the best answers will come from those also exposed to 10- and 20-below weather.
5 meter Langford Nahanni
Old 11-12-2006, 07:49 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Seems like the manufacturers have likely check this out and have documentation on their particular sets. There usually is a free 800 number for customer service in the documentation. I think you should call it because not all sets are designed the same.
Old 11-12-2006, 08:12 AM   #4
Craftsman
Guest
Posts: n/a
Carol, I leave a small oil filled heater on all winter in the 25' that I recently sold and now my new one. The kind that looks lake a small radiator.Completly sealed , no flame ,nothing to overheat and even in the coldest weather it never freezes.
Jack
Old 11-12-2006, 08:28 AM   #5
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Error on the safe side, take it out.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 11-12-2006, 08:42 AM   #6
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Carol-
Greeting from New Ennland. I have never heard of needing to keep LCD screens from freezing. Very strange and I never would have thought of it. There is no "liquid" to freeze in the unit, it's electronic. We leave our in the unit with never a problem. I would be more concerned with disconnecting it, unbolting it, storing it and then reversing the process in the spring. Even the dealers up here leave all the parts in the AS during winter. So make your winterizing a little easier and leave your LCD right where it is.
Happy camping!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 11-12-2006, 10:00 AM   #7
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
We leave both LCD units in our Airstream in sub-freezing conditions and to date have not experienced problems.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 11-12-2006, 11:27 AM   #8
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Ours has been out in the cold for the past three winters....not a problem.
It gets to minus 20 around here.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 11-12-2006, 12:50 PM   #9
jimmickle's Avatar
2000 31' Land Yacht
The maker of my Sharp says don't let it freeze, so I didn't.
jimmickle is offline   Reply With Quote
Old 11-12-2006, 08:45 PM   #10
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by rickandsandi
Carol-
Happy camping!
Hi, correct me if I'm wrong; LCD stands for "Liquid Crystal Display" Thus there is liquid involved.
Old 11-12-2006, 08:57 PM   #11
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The instructions for our Sylvania LCD TV specifically don't say anything about it. They do say to avoid heat, but do not say to avoid cold.
Old 11-12-2006, 09:04 PM   #12
_
you aren't serious are ya bob?
the 'liquid' word refers to the liquidity of the display...as in fluid motion.
the crystals are suspended and behave in a fluid/liquid fashion rapidly changing orientation...
but there isn't any fluid in an lcd...good grief.
have ya check your blinker fluid lately?
anyway carol the sony manual states specifically what the operating temperature range is and what the safe storing temp is.....so just look it up.
i've routinely left mine in the trailer down to 10 degrees....
but operating temp is higher, so warm the trailer before using it....
a greater issue than the lcd is that at these very cold temps and very low humidity the goop that holds all the circuits together will dry out and retract....
so really really cold isn't good for long shelf life...
cheers
2air'
also i forget to mention the wega sony we've got has been discontinued? like all electronics models move on...
sony does have some models in the 'bravia' line that with wider operating ranges ....like minus 15 degrees F up to 185 degrees F...
i'm not watching tv at these temperatures regardless...
Old 11-12-2006, 09:20 PM   #13
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Easy 2air, not having knowlege about some technical area is no crime....is it?
Checked your blinker fluid? You usually write good posts, but you may be off on this one.
Fyrzowt is offline   Reply With Quote
Old 11-12-2006, 09:22 PM   #14
Salem , Oregon
Images: 18
Hi, No 2air I didn't know; That's why I said "correct me if I'm wrong." No I have not checked my blinker fluid! Have you ever repaired Sure Track Brakes? Or have you ever worked on Hydrolic Wiper motors? Have you ever used Friction Modifier? Do you know what very common part used on vertually every American car dateing clear back into the fifties has a metric measurement?
Mount LCD TV dcbollinger Audio, Video & TV 4 07-11-2006 05:49 PM
Securing LCD TV flynmike Audio, Video & TV 4 06-09-2006 09:05 AM
Under cabinet LCD? FlyFishInn Audio, Video & TV 6 05-29-2006 09:56 PM
LCD monitors GreggH Audio, Video & TV 11 02-24-2006 12:03 PM
LCD TV Mount tandemfish Argosy Motorhomes 4 01-20-2006 07:33 AM
