Old 10-06-2016, 09:34 PM   #1
Cloudland2
davidrrand's Avatar
2016 25' Flying Cloud
Trenton , Georgia
Cable TV??
Stayed at our first campground with a cable TV hookup in Amarillo a couple nights back. Did not have a coax to connect to the outside trailer port labeled "satellite/cable so did not get to try this. Will get a 12 foot cable in case this comes up again. What else would I need to do to receive the cable programming through the stock Samsung TVs in my 2016 FC? I do not see a "cable" option under the "source " button on the remote, only "TV" and "HDMI1".
ThAnks for your help! 😃
davidrrand is offline   Reply With Quote
Old 10-06-2016, 09:49 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
You will select TV on the remote for both antenna and cable. You will press the button on the plate where your TV connects to the antenna to turn the green LED off. That changes the signal on the coax from the antenna to the TV cable outside connector. If you have a plate with two coax connectors on it, there should be a jumper between those connectors. You will then have to scan for channels on all TVs. When you go back to antenna, turn on the LED with the pushbutton and scan for channels again.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-15-2016, 11:31 AM   #3
dasams's Avatar
Marin , California
Do yourself a favor and buy a 25' flexible mini- coax instead of the stiff types. See https://www.amazon.com/C2G-Cables-Go...ni-Coax+F-type
Also as noted above, plug into the Cable port, not the Sat port and use the white plate inside to toggle between the antenna and the cable signal. This signal enters your Samsung using the TV input. HDMI1 is the input for the BlueRay.
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 08:16 AM
Trailer breakaway cable wayner1239 Brakes & Brake Controllers 47 12-08-2003 06:13 PM
Cable tv question TexasStars Electrical - Systems, Generators, Batteries & Solar 4 10-23-2003 04:35 PM
Spedo cable adapter. SebastianD Airstream Motorhome Forums 1 09-14-2003 06:07 PM
Argosy throttle cable mcneon Mechanics Corner - Engines, Transmission & More... 7 08-24-2003 09:17 PM
