Old 01-26-2011, 09:28 PM   #1
NicheVintage's Avatar
1965 26' Overlander
Scottsdale , Southwest
Images: 34
Cable jack options for exterior skin
The pictures attached are what I currently have. I want to patch this existing location and create a new location near the bedroom as that is where the new tv location is. Seems that the PO just drilled a hole and used a poor excuse for a rubber grommet as a seal.
Can some one post up some pics of what they did for a new cable jack install? Seems that there has to be a better way.
ID:	120172   Click image for larger version
NicheVintage is offline   Reply With Quote
Old 01-27-2011, 06:21 AM   #2
richinny's Avatar
2011 34' Classic
Westchester Cty.NY , / Miami FL
here is one solution:
http://www.airforums.com/forums/f451...ver-44896.html
my jack is located in the compartment with the shore power cable. you might consider using wire/cable that has the capacity for satellite. you might also want to add a phone jack at the same time.
Ricky
richinny is offline   Reply With Quote
Old 01-27-2011, 06:58 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I forget where I got it, probably an RV/ Trailer supply but I have a external jack mounted on a square aluminum base which would both give you a patch and a jack connection.
Old 01-27-2011, 01:31 PM   #4
2005 19' Safari
GLENDALE , AZ
Take a look at marine parts stores, like West Marine and others. They have a lot of hardware that works great with Airstreams.
Phoenix is offline   Reply With Quote
Old 01-27-2011, 02:23 PM   #5
1995 25' Excella
waynesboro , Virginia
Our 73 has an antenna which cable comes in the cabinet behind and to the right of the refrigerator, curb side.....I drilled a hole through the shelf floor, behind the sliding door .....this permits the cable,( which is stored in the access to the rear of the refrigerator) to come up and through when needed. When not used the coax cable is tightly bound in this compartment. Also made a small opening in the screen in the lower of the compartment to run the cable when we have access to cable tv......
waltero is offline   Reply With Quote
Old 01-27-2011, 03:13 PM   #6
Grand Master's Avatar
1963 24' Tradewind
Anderson / Sun City , Indiana / Arizona
It looks like your antenna wire comes out just curbside of the front window, and originally hooked into the old antenna. My '62 used to be similar.
I completely deleted the original antenna and wire by patching the holes. I then ran a new cable from where my TV was mounted to the rear of my trailer (on the street side so that it would be handy). I have a "trap door" that houses my electric cable, and I simply utilize that same compartment for my coax. It allows for about 20' of cable to be ready to be uncoiled and attached to the RV Park utility connection. I don't see a similar access door on your trailer. Perhaps you could utilize the bumper compartment, or the small door on the curbside.
If you look at the lower rear corner of my trailer you can see that my electric, cable, and water are all connected from this one access point.
Mike Brumback
WBCCI #1200
Grand Master is offline   Reply With Quote
Old 01-29-2011, 06:43 PM   #7
1965 26' Overlander
Images: 34
Thanks everyone for the great suggestions. I ended up going onto a marine company site and found a great option for a very reasonable price. Now we are trying to figure out where to out it. We like grand master's idea and may do something similar. Thanks again.
Old 01-30-2011, 05:32 PM   #8
1965 26' Overlander
Images: 34
Here is the link to what we found in case anyone is looking for something similar.
http://www.westmarine.com/webapp/wcs...classNum=11106
Thanks again.
Old 01-30-2011, 06:20 PM   #9
Mexray's Avatar
1978 28' Ambassador
Morada , California
Here's what I did...I know it ain't pretty - but it covered up an ugly spot that had an old, broken, automotive radio antenna base attached...
I have a length of coax attached on the inside so I can either hook it to the TV if using an RV park cable TV hook-up....OR....
I can hook the coax inside to the back of the Sat receiver, and then bring the TV outside and hook another short coax to the TV for outside viewing...
Name:	IMG_1598 [Desktop Resolution].JPG
ID:	120978   Click image for larger version
Name:	IMG_1599 [Desktop Resolution].JPG
Name:	IMG_1600 [Desktop Resolution].JPG
Ray & Pat; Morada, CA
Porter Cable Orbital vs Cyclo Becky B. Cleaning, Stripping & Polishing 30 06-23-2013 08:14 PM
New Airstream Options: Springfield-Branson Missouri MO Airstream Commercial Listings 7 10-27-2011 10:49 PM
Breakaway cable length? oceantribe Brakes & Brake Controllers 12 01-10-2011 04:18 PM
window operator replacement options GR8DANE Windows & Screens 17 01-10-2011 09:09 AM
