Old 10-18-2015, 08:38 PM   #1
2017 25' Flying Cloud
1964 17' Bambi II
Ogden , Utah
Cable hook ups
We have a 2016 Bambi Sport with a cable hook up. How do we hook up the cable in a campground? Do we need to bring a special cord? Thank you.
mcaslaon4449 is offline   Reply With Quote
Old 10-21-2015, 10:25 PM   #2
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
You will need a length of RG6 cable terminated with F-connectors. Just like the cable you use at home from wall to cable box. You can purchase pre-made length of these at Walmart and tons of other places.
GE Quad Shield RG6 Coax Cable, 25' - Walmart.com
Then you connect outside from the cable the campground provides to the side of your AS. Inside you should have a small black button on the cover plate behind the TV - make sure you press button and turn light off to disable the amplifier (used for the roof antenna). Then go to the menu on the TV and look for the area to search for CATV signals. Let it run through its process and you should be all set.
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Hook ups Connections for the easy life rodsterinfl On The Road... 30 10-25-2015 03:43 PM
Full hook-ups close to Port Orchard, WA? DianePhx On The Road... 2 07-23-2014 12:07 PM
hook ups for water tank , pump and tie ins batt Fresh Water Systems 3 10-03-2010 07:10 PM
Hook ups? watt1968 Plumbing - Systems & Fixtures 12 05-01-2008 05:53 PM
West Cheap or Free Hook-ups - MT CTHilmo Boondocking 3 04-09-2006 08:45 AM
