Old 04-05-2014, 12:22 PM   #57
CA_Tallguy's Avatar
1977 31' Excella 500
Zavalla , Texas
Amazing! My rooftop Trav'ler just pulled in a signal through (or over the top of) this massive tree! I thought for sure that this would be the first time I was blocked by trees from using the rooftop dish.
I was encouraged on arrival when I saw a neighbor had set out one of the winegard domes on a tripod, but I'm still amazed. Another neighbor, a bit closer to the tree, has a regular dish out in a clearing on a tripod with at least 100 feet of cable. Maybe 200 feet.
I tried to capture the issue in the attached photo and highlighted the back of my dish as it was hard to make out.
I'm in Houston so I was feeling fortunate that I'd be able to go to PPL to get a set-out type dish, assuming that this wasn't going to work. Glad there turned out to be no need!
These things must be pulling the signal from a much higher angle than it appears to be pointing. It makes sense as I think the signal bounces from a higher angle, off the back of the dish, and down to hit the end of the bar with the LNB's at the lower angle. The bar for the LNB's just fools the mind into thinking the bar itself is pointing at the satellites.
WBCCI #1711
Texas Gulf Coast Unit, Texas Airstream Harbor
Angelina National Forest, Zavalla, TX
CA_Tallguy is offline   Reply With Quote
Old 04-05-2014, 11:23 PM   #58
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I finally did it. Travler with DishTV. So far so good and no complaints. I will be hitting no road in a few days so anxious to see how it performs at different campsites.
TinCan
graysailor is offline   Reply With Quote
Old 04-06-2014, 04:08 PM   #59
Halimer
2006 25' Classic
New Hyde Park , New York
I'm looking at the new Winegard G2. It will do Direct TV, Dish and Bell. Same size as X-1.It seems to be an upgraded Winegard X-1.
Winegard Company - Dealers.Winegard.Com
Halimer
halimer is offline   Reply With Quote
Old 04-08-2014, 07:42 AM   #60
TinCan
graysailor's Avatar
2016 30' Classic
Everything installed and working but yesterday I added an external HD to turn my Receiver into a DVR. No luck....Dish support can't understand the problem. They/we tried for over an hour to get the HD to download the software but the receiver still won't recognize the HD. Not sure what to do about this issue.
TinCan
Old 04-08-2014, 07:59 AM   #61
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
While most major manufacturers' external hard drives are compatible, keep in mind the following guidelines when purchasing an external hard drive:
When using an external hard drive with a ViP 612, 622, 722, 722k, 922, or Hopper, the drive should be no smaller than 50 GB and no larger than 2 TB.
When using an external hard drive with a ViP 211, 211k, 211z or DISH 411, the drive should be no smaller than 50 GB and no larger than 2 TB.
The external hard drive must have its own power supply.
The external hard drive must support USB 2.0.
The external hard drive must not use flash memory and should only be a single-hard disk drive.
Assuming that you meet the requirements above, the only things I can think of might be a problem with the receiver and or the port it is plugged into, a bad usb cable, or a problem with the drive itself. Have you tried to plug the drive into a PC just to see if it is functioning?
One of the other things I remember reading (and I don't know if this is still true), that Dish receivers may have problems with hard drives that have energy saving power circuits. Some drives will spin down when not in use and I remember that at one time Dish receivers didn't provide the signal to "wake up" sleeping drives. That's why Dish recommends the Western Digital AV model external hard drives. Those disks don't spin down. I noticed that Amazon is selling the 1 TB model for $87 and free shipping right now.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-08-2014, 08:07 AM   #62
jcanavera's Avatar
Fenton , Missouri
Images: 143
Not totally a big surprise. The further south you go, the satellites tend to be higher in the sky due to their orbital locations. As you go north you start moving your aiming point further down towards the horizon and trees and other obstacles become more of a problem. In all cases the signals that the dish is seeing comes higher up in the sky than the angle of the LNB which is receiving the signal that is reflected from the dish itself.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-08-2014, 08:26 AM   #63
jcanavera's Avatar
Fenton , Missouri
Images: 143
There was some talk in this thread earlier in February regarding eastern arc or western arc satellites for Dish network and which arc to point to. Just as an update, for home antenna placements, Dish for the last month has now been giving their installers the order to point towards the eastern arc unless it is not available.
I found this out due to the fact that I was upgrading a Hopper receiver in my home and was surprised that they were going to send an installer out to do this. I asked why they just would send out the Hopper so I could swap, and was told that the installer would bring out a new LNB and was going to aim me to the eastern arc satellites. I talked to advanced tech support and they told me that the orders have come from engineering to point to the eastern satellites but they have no explanation as to why this change is being made.
My son just did got Dish this last weekend and the installers orders were to point east, although they had to point to the westerns due to a tree.
Rumors abound, and one is that there is a problem with one of the western arc satellites but I can't substantiate that as of yet. Another rumor is that HD signal strength is better looking at the eastern arc. The installer at my son's house disputed that (at least in our area of the country). He also noted that all of the orders he has handled in the past month have been telling him to point to the eastern arc. He has no clue as to why this change occurred since pointing to the western arc was the norm for this area.
I did ask the Tailgater support tech at Dish as to what this means for the Tailgater and he noted that he was aware of no changes and that the Tailgater will continue to only look at the western arc satellites.
I'll prowl around on some of the satellite forums and see if I can get any further info as to what is going on.
Jack Canavera
STL Mo.
AIR #56
Old 04-08-2014, 12:13 PM   #64
CA_Tallguy's Avatar
Zavalla , Texas
Which receiver are you using and what brand/model is the hard drive?
I highly recommend that you use a Hopper DVR in your trailer since you have that luxury with the Trav'ler!
WBCCI #1711
Old 04-08-2014, 12:25 PM   #65
CA_Tallguy's Avatar
Zavalla , Texas
Re: eastern or western arc -- for a fixed install, this matters more than mobile. But each market with dish is generally setup more for one arc than the other. Very large markets might be on both, however. Now, when I say "set up" for one more than the other - I mean that your locals might be in HD on one arc and only SD on the other. I hear about a lot of folks who are pointed to the wrong arc because the installer was either lazy or didn't know any better.
The further you go into the northeast, the more you'll likely need to be on eastern arc. Not only for the above reason, but in order to have a good view to the satellites.
Otherwise, for mobile, it's nice to have a solution that can look to either arc as you will have a better chance to clear obstructions blocking one or another.
Unfortunately, my Trav'ler is only setup for western arc. Interestingly, however, in setup the other day, the dish DID lock on to an eastern arc satellite for a moment while searching for western satellites. The receiver even kicked in with programming. I suspect it might only be able to lock onto one satellite at a time on the eastern arc because the spacing of the LNBs on the arm and position of the arm are setup for western spacing.
It's unfortunate that Winegard doesn't have a manual mode that would allow me to manually do this anyway. Then I could at least have a chance to lock into one eastern satellite if my western arc view was blocked. I might try a workaround in the future and be ready to pull the power if and when it temporarily locks onto an eastern bird in a search like this. Certainly not ideal as the search pattern may not be very predictable.
WBCCI #1711
Old 04-08-2014, 12:28 PM   #66
CA_Tallguy's Avatar
Zavalla , Texas
Name:	ImageUploadedByAirstream Forums1396981611.521800.jpg
A different view of the tree I'm clearing right now (on the left). My dish is almost perfectly centered on the tree.... It's a massive tree. Never would have thought I could clear such a large object so near to the trailer.
WBCCI #1711
Old 04-08-2014, 03:11 PM   #67
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
The direct broadcast dishes are called offset feed. Unlike the old large round dishes where the focus is perpendicular to the dish, as you suspected the focus is approximately the mirror image of the line from the center of the dish to the feed lnb. This puts it substantially higher than you might think. The multiple feeds also laterally spread the aim point out for different satellites. The tree may be blocking some feeds but not all.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 04-08-2014, 10:23 PM   #68
TinCan
graysailor's Avatar
2016 30' Classic
I guess I just needed to wait a day. Receiver and HD are now connected. The dealer sold me the receiver otherwise I guess you have to lease the receiver and I bought the HD. I went with the 120 channel option so time will tell if that is enough. A lot of channels that I will never watch.
TinCan
Old 04-09-2014, 11:30 AM   #69
jcanavera's Avatar
Fenton , Missouri
Images: 143
From what I have been able to determine, Dish is moving some cities to the eastern arc satellite to free up space on the westerns.
This is a list of cities that are having new customer eastern arc installs . Probably means that someday or some year, the SD western arc feeds for these will be shut down. But, lots of service calls before that could happen.
Charlotte,NC
Birmingham,AL
Minneapolis,MN
Raleigh,NC
Tampa,FL
Joplin,MO
Cleveland,OH
GrandRapids, MI
Ft.Meyers, FL
Norfolk,VA
Richmond,VA
Detroit,MI
W.Palm Beach, FL
Orlando,FL
PerryCounty, MO
Savannah,GA
Nashville,TN
Memphis,TN
Mobile,AL
Charleston,WV
Huntsville, AL
Kansas City, MO
Des Moines, IA
St. Louis, MO
Pittsburgh, PA
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-24-2014, 10:54 AM   #70
TinCan
graysailor's Avatar
2016 30' Classic
I have not really had a TV for over 10 years (no channels only used for movies) so I was kind of excited about getting the Sat system. 120 channel option and so far quite disappointed with the programing. Not much of anything worth watching. i.e.. The History Channel has nothing to do with history and A&E is just as bad. Hate to spend another $50 for 50 more useless channels.
TinCan
