Old 01-21-2014, 11:18 PM   #43
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Ok, more info too absorb. I am a US citizen but I live in Mexico for about 6 months of the year so the Airstream is home up North for 6 months which is why I need to get it right the first time. Also all research is done on the Net so no one really to talk to. Your input I am sure is being read by others. Thanks again. I will spend a day re reading your posts.
TinCan
graysailor is offline   Reply With Quote
Old 01-27-2014, 08:10 AM   #44
TinCan
graysailor's Avatar
2016 30' Classic
Pretty much have things figured out at last. In sniffing around the internet it seems to be a toss up between Dish and DirectTV. Lots of pros and cons for both. Many seem to have switched back and forth.
TinCan
Old 01-27-2014, 02:12 PM   #45
CA_Tallguy's Avatar
1977 31' Excella 500
Zavalla , Texas
Breaking Down Satellite TV Dish Options
The main reasons to use dish are (1) generally cheaper and (2) if you care about HD and you intend to use a tailgater or other set-it-out type unit.
Not trying to push dish but just want to make sure you realize that you can't get HD as easily with directv when mobile in an RV. The ONLY ways to get HD on directv are with the $1500 Trav'ler unit OR by toting a full sized dish with you that you set up manually in a tripod. There is no tailgater or other set out type device that will give you HD on directv.
The HD flexibility is probably the #1 reason I paid an early termination fee to give up directv in favor of dish when I became an rv full timer.
WBCCI #1711
Texas Gulf Coast Unit, Texas Airstream Harbor
Angelina National Forest, Zavalla, TX
CA_Tallguy is offline   Reply With Quote
Old 01-27-2014, 03:12 PM   #46
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
The other benefit of Dish for part-timers is that the receiver can be part of your home system and just pull it out and place it in the RV when traveling. The only additional cost then is the Tailgater. The Tailgater finds the satellite automatically by programing what state your in. However I have been able to get Denver stations in northern New Mexico by programing it for Colorado. Perhaps that might work if in Mexico, by programing for AZ but might be best to check with the Dish RV department.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 01-27-2014, 03:50 PM   #47
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Has anyone tried contacting Wingard to see if they have any "open box" units available. These are units that have been opened maybe returned by a dealer but new and not used. When I installed the SK-1000 Traveler on my AS a few years ago I was able to get an "Open Box" unit for about half the price of a new one. The one I received was brand new and looked like it had never been out of the box. It only had a 90day warranty but that was fine. I went through their support department when I got it. It still works great, the Traveler is the way to go in my opinion.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 01-27-2014, 04:59 PM   #48
CA_Tallguy's Avatar
Zavalla , Texas
Great idea adonh! Wish I would have thought to check before buying mine.
WBCCI #1711
Old 02-06-2014, 09:22 PM   #49
Halimer
2006 25' Classic
New Hyde Park , New York
Has anyone looked into the Winegard Pathway X1? It works with the Dish211z.
Winegard Pathway X1 for DISH - DISH HD Portable Satellite TV Antenna
halimer is offline   Reply With Quote
Old 02-06-2014, 10:50 PM   #50
1999 30' Excella 1000
small town , Maryland
I didn't see rabbit ears on the list the kind you move until the snow went away. Maybe I should buy a new television, theirs no place to test the tubes anymore. I hear they have color sets with a 20'' tube. What ever happen to the test pattern in the morning? Those were the days. Thanks for bringing me up to speed
streaminwild is offline   Reply With Quote
Old 02-07-2014, 03:35 AM   #51
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Images: 8
We used the morning and late evening test pattern to align the color guns in Heathkit home built color Television sets in the 70s.
Old 02-09-2014, 10:16 PM   #52
CA_Tallguy's Avatar
Zavalla , Texas
I have not... but is there a reason you like that unit over the X2? The X2 can see both eastern and western dish arcs so that is a HUGE benefit!
For example, if you have an obstruction blocking the western arc, you might still be able to see the eastern arc.
In addition, I recently found out that in some cases dish only has HD local channels in certain markets on one arc and not the other. For example, right now I am in east texas and my very expensive rooftop unit only gets western arc.... As a result, I can't get the east texas locals in HD (I only get the SD signal on the western arc so I can still see them, but not HD). As a workaround, I figured out I am within the reception area for Houston so I told dish I was there so I am watching their locals --- and their HD locals are available on the western arc.
The further you go into the northeast, the more important/advantageous it will be to have the eastern arc option in order to get your full programming (and for your best chances at a clear view to get any programming at all). Off the top of my head, I'm not sure if many other solutions have this east/west arc option but I do think it is a "killer" feature worth strong consideration.
WBCCI #1711
Old 02-10-2014, 11:47 AM   #53
CA_Tallguy's Avatar
Zavalla , Texas
I'm glad you posted about the X1 and got me thinking about that vs the Tailgater and X2, Halimer. I had been expecting to pick up one of these units for cases when my rooftop mount might be blocked and had forgotten about the eastern arc benefits of the X2.
The conversation prompted me to spend some time looking at the three options this morning. It looks like the main benefit to the X1 would be size, and that it can be "permanently" roof mounted with the ability to detach it when desired.
Here are the dimensions of the units... keep in mind that smaller may not always be better here! Winegard says that the larger reflector in the X2 helps with reception, so there is a tradeoff between the two (and likely the same with the tailgater as it is closer in size to the X1).
Tailgater - 16" x 16", 17.5" height
Winegard X1 - 14.3" diameter, 13.5" height
Winegard X2 - 21" diameter, 15" height (stowed)
The roof mount/detachable flexibility was something I was considering before I decided to go with the pop up Trav'er dish. In the end, the Trav'ler was a better choice for me as it allows you to use any Dish receiver and since I am a full-timer I wanted to be able to use the Hopper in my trailer. If I was only using my Airstream for recreation, I probably would have been more open to the limitations of these set-out type units.
I also worried that the little bubble popping up on the roof might look odd on an airstream.
Here are links to the various units on Amazon... (note that the winegard units linked here are bundles with a receiver and the tailgater is just the antenna)
Tailgater - Dish VQ2500 Tailgater Portable Satellite
Winegard X1 - Winegard PA2000R Pathway X1 with VIP 211z
Winegard X2 - Winegard PA6002R Pathway X2 Bundle
It seems like the winegard units are both just a little more expensive than the Tailgater at the present time. I'll have to read though user reviews to help decide before pulling the trigger, but I'm strongly inclined to go for the X2 for ability to use the eastern arc + western.
Note that you can buy the antennas separate from the receivers, which might be a good idea to make sure you get the latest receiver (the 211Z, which is a lot smaller than the previous 211K). I would guess that the bundles are also shipping the 211Z now as it has been out awhile but personally I'd be disappointed if I ended up with the K model.
WBCCI #1711
Old 02-11-2014, 07:29 AM   #54
Halimer
2006 25' Classic
CA Tall Guy,
Thanks for all the info. I'll need to check out the different channel offering on the eastern arc. I would prefer the Winegard X1 due to its size. I can easily fit it under my bed. I carry to much stuff on a 3-4 month trip in the bed of the truck. I have the Winegard MP1 Carry Out. It takes forever to adjust and set up. I took me less time to set up man portable mil SATCOMs or even a bi-pole antenna in the military. And I wasn't the Commo guy! A Winegard rep said that it takes him 10-15 to setup the MP1 Carry-Out, and he does it all the time.
Thanks for all the research.
Mark
Old 02-11-2014, 10:32 PM   #55
CA_Tallguy's Avatar
Zavalla , Texas
A good place to research what channels are on which satellites with dish is at James Long .name
Here are some overview maps showing the spot beams coming from one eastern and one western arc satellite.
Name:	Screen Shot 2014-02-11 at 11.22.41 PM.png
I'm inferring from this that the satellites are maybe over the southwestern and southeastern states -- maybe off the coast? It generally looks like there could be a 90 degree or so difference in where the dish would point on the ground in much of the US, which could really provide a great deal of help in being able to receive the signals.
One thing I wonder is how hard it is to switch from western to eastern arc both in the dish unit and the receiver. It would be amazing if it were seamless and both the dish and the receiver would pick and choose which arc is best to use, but I suspect that it may not be that simple. Probably wouldn't be too hard though. My guess is that you might have to change a setting in the receiver. I think the X2 would be able to automatically figure it out on its side but there could be a reason why they might make you flip a switch or something on it too.
WBCCI #1711
Old 02-11-2014, 10:38 PM   #56
CA_Tallguy's Avatar
Zavalla , Texas
Sounds like the user would just re-run the setup and choose the alternate arc if the X2 unit was unable to lock onto the first arc selected...
Q. Should I choose eastern or western arc during receiver setup?
A. Generally, western arc will be available in almost all areas of the continental US. When in the eastern half of the US, the eastern arc may provide better look angles and possibly local channels if you are within your home market.
Q. How do I access the receiver setup menu after initial receiver setup?
A. Press “Menu” on your remote. Select option 6, “System Setup.” Then, select option 1, “Installation.” Select option 1 again, “Point Dish.” Finally, select “Check Switch.” Adjust settings as desired.
Q. Do I need to go through all receiver setup steps every time I use the antenna?
A. Every time the antenna is moved to a new location, you will need to complete receiver setup. Simply choose the number of receivers (one or two), eastern or western arc satellites (no selections need to be made if “Two” was selected for receivers), and the state that you are currently in. Then, select “Scan” to begin scanning for satellites.
Q. What do I need to set up the Pathway X2 antenna?
A. You will need a TV and an activated receiver with programming package. The antenna must be used with a DISHSolo HD receiver; examples include DISH 211k, 211, 411, and 211z receivers.
WBCCI #1711
