Old 02-22-2007, 10:58 AM   #1
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Bose speakers?
I am currently in the planning stages of this springs refurbishing. Among some of the things I am considering while the Trade Wind is in dry dock is a serrious upgrade on the audio front. Has anyone tried something like these Bose Virtually Invisible 191 Stereo Speakers - In Wall and In Ceiling Speakers
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-22-2007, 11:17 AM   #2
Blu_Hwy_Lady's Avatar
1972 23' Safari
Placitas , New Mexico
Those are very cool looking speakers. I replaced the speakers in my Safari with car stereo speakers because I was told that the road vibration would destroy regular home speakers. Since I know absolutely nothing about audio stuff I just believed it because it kind of made sense. Having ridden around a parking lot in my trailer, I know it's pretty bumpy. And, seeing the way things get moved around after being on a rough road it make sense. So, I'm eager to find out what other people have to say about the audio option...now that I'm stuck with my rather unattractive but very functional car speakers.
Airylle 1972 Safari featured for 5 nanoseconds in the movie Wild Hogs
and
Jupiter (the Golden Retriever)
Blu_Hwy_Lady is offline   Reply With Quote
Old 02-22-2007, 11:25 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Bose is high-spensive with a lot of $$ going toward the name. Any Best Buy automotive auditioning room should help you find something just as good. Know I've seen Bose theater-in-a-box at BB -- not sure if they have Bose auto systems to hear.
5 meter Langford Nahanni
Old 02-22-2007, 12:09 PM   #4
1972 23' Safari
Canoe: did I get the right info that you really can't use regular home audio stuff in an Airstream? BTW, I have 'spensive Bose in the house...
and
Old 02-22-2007, 12:25 PM   #5
You can use home audio in an Airstream but it is bulkier & one would need an electric plug-in since it is 110v. Automotive audio is more versatile because it will run off the battery if boondocking or on 12v through the converter if you do have a plug-in. I do not know if the speakers are interchangeable; ie, does a home audio system's transformer supply the same wattage to the speakers. Hope we'll snag somebody reading this who has looked into this.
Old 02-22-2007, 12:26 PM   #6
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Having speakers in the shell structure would be fine vibration wise if your running gear is well balanced - I'd worry about condensation though. I plan on using older surface mount Bose acoustimass speakers as I am of fan of their direct-reflective sound.
Car audio amplifier output is different from home audio; the voltage-current ratios for driving automotive speakers has higher voltage : lower current to better overcome distortion from vibrations, thus why yesteryear shoestring garage sound systems cobbled together from car/home or home/car radio-speaker combinations ALWAYS sounded horrible.
If you drive the Bose speakers from a home audio system they should last just fine and sound good too, courtesy of torsion axles and shock absorbers. Just beware of condensation if you put them in the shell.
Old 02-22-2007, 12:36 PM   #7
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Very cool speakers but you may have a few problems; first they measure 4" deep which will cause an instalation problem in the depth. You could build a face plate but I wouldn't think that would be too desirable. In addition you will need to add a pre-amp. A 12V system will not be enough to drive these. You will do much better finding a high end auto speaker for flush mounting, but then again you will have the depth problem unless you mount them into a bulkhead.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-22-2007, 12:45 PM   #8
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Acoustimass
The Bose Acoustimass system is excellent, and very reasonably priced for the quality. I don't consider it audiophile high end, but it does a good job with a braod variety of music. ( Bose Acoustimass 3 Stereo Speakers - Home Theater Speaker Systems ) I use an Alpine Car audio amp, and feed it directly with my ipod. Went and got a remote for the ipod ( $ 45.00) which works through the cabinetry. Now I have an all but invisible system that sounds really good to my ears, and is very light and small. Plus, it works while boondocking. When I watch movies, I hook it up to my laptop, and have big sound.
Yes, I would do it again, in a heart beat. I am thinking of getting a second set of the acoustimass speakers for the front area.
Uwe
www.area63productions.com
Old 02-22-2007, 01:44 PM   #9
mandolindave's Avatar
another thing to consider..........
I don't have specifications of those specific speakers, but Bose are historically power hungry.
mandolindave is offline   Reply With Quote
Old 02-22-2007, 03:42 PM   #10
2004 25' Classic
West Chazy , New York
I consider myself an audiophile and have high end but not esoteric equipment at home. That being said, I installed a Bose 3.1 system in my AS. Given the close quarters, the Bose is quite enjoyable. I have the satellites mounted on the fridge/mw wall and on the end panel of the cabinets above the galley. The top of the speakers are at the ceiling - not the best for sound, but do not present a clearance issue by the entance door. The distance from the speakers to the couch is equal on the Classic 25. I have the "player unit" on the credenza and the subwoofer in the cabinet below. The wires to the woofer and a few pieces of security tape under the feet of the player keep it in place nicely. I was able to run the wires to the speakers invisibly by tucking them behind the wall and then under the vinyl strip that is on the ceiling.
Of course I need shore power, but I don't boodock yet. I need to have a/c or I will float away, but when I buy a gen I will be able to be comfy and hear good tunes wether I'm plugged in or not. All in good time! Anyway, I just wanted to share what I did.
Ron
2004 Classic 25 - The Silver Sausage
2008 Silverado LTZ CC 2500 4x4 Duramax - Brutus
WBCCI 2623
romap is offline   Reply With Quote
Old 02-22-2007, 04:53 PM   #11
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Higher end bose stuff, like their 901's are definitely power hungry. The Acoustimass 3 system seems quite efficient. With a 2x100W Alpine car audio amp, I only need to set the ipod volume to 1/4 of it's travel, and it's already good and loud. I chose their white colored system, since my drapes and interior walls are mostly white.
btw. I run this system without any tone controls, just ipod out into the car audio amp - and it sounds very natural and pleasant, without hissy trable or flabby low end. It sounds more expensive than what it is to me.
Uwe
Old 02-22-2007, 05:05 PM   #12
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
So to do this I would need to get a car amp and thats the only other thing to make it Airstream ready? The only down side I see to this would be where to put the larger unit. Does it matter where it is in relation to the other speakers?
Rodney
and the
My Blog
Old 02-22-2007, 05:13 PM   #13
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
It seems to matter only little in such a small space. I have my sub under the closet floor, in front of the converter, blowing through a round cutout in the lower closet door. Bass waves are somewhat non-directional. In my case, it sounds like the bass is coming directly from the small cubes.
I suppose you would want it near the cubes somehow, not in an opposite corner of the trailer. Near can mean up to 6-8 feet away.
You can also use a decent car stereo or CD combo player to power the system, in which case the amp would not be needed.
However, I like power and headroom, therefore I like a beefy amplifier.
Uwe
Old 02-22-2007, 05:58 PM   #14
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
I wonder
I wonder if the large box in that set up would fit under the front goucho? Would that be a decent placement if it would?
Rodney
and the
My Blog
Got speakers? KHarris Audio, Video & TV 7 06-14-2010 06:13 PM
speakers on wall brunoffrance Audio, Video & TV 0 05-22-2006 12:41 PM
rear speakers ALANSD General Motorhome Topics 4 01-25-2003 03:33 PM
Stereo Speakers kntd Audio, Video & TV 4 01-20-2003 06:37 PM
AV Wiring Neenm Electrical - Systems, Generators, Batteries & Solar 6 09-20-2002 06:54 AM
