Old 03-30-2014, 06:09 PM   #1
Naples , Florida
Best easiest to TV reception>
Just bought a 2007 Classic 27FB. What is the best way for my to go as far getting TV signals. I've heard some about these portable Satelites that set themselves up by looking for the signal and can go through trees and such. Winegard has one for $700. Any thoughts. Thanks Bob
hobbs1949 is offline   Reply With Quote
Old 03-31-2014, 06:34 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
The Winegard Sensor III antenna that should have come with your trailer should do pretty well as far as broadcast television.
The various satellite TV alternatives are expensive but some people have good luck with them. The portable ones require a fair amount of setup. From what I have seen trees and other obstacles do block reception at least some of the time.
Old 04-01-2014, 10:32 AM   #3
Ayr , Ontario
Do you not need a digital converter now to get any type of reception?
gator.bigfoot is offline   Reply With Quote
Old 04-01-2014, 11:51 AM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
Not with a recently manufactured television.
Old 04-01-2014, 06:36 PM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
The TV's in my 2007 require converters.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 04-01-2014, 06:47 PM   #6
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
We purchased a new TV (i.e. digital) and it works fine with the original antenna equipment on our 1992 Classic. We simply crank the antenna up, use AntennaPoint.com on a smartphone to find the direction of the signals, then rotate the antenna to the appropriate angle (using a simple compass). After that we use the menu on the TV to scan for the channels in the area and we receive the local stations. Works fine for us.
In some locations, the broadcast signals come from varying directions. If the signals are weak, and the signals come from dramatically different directions you might have to rotate the antenna depending on the channel you want to watch. This situation is true for us about 50% of the time.
By the way, we use a similar approach at home - we have new digital TVs but we use an old-fashioned multi-element antenna and we receive all the channels in our area.
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is online now   Reply With Quote
Old 04-01-2014, 07:14 PM   #7
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
For short stays the on board antenna should work fine. Obviously very local channels will be best so research the channels in your area. As for satillite service, I am very satisfied with Directv. I puchase a manual satillite dish from Camping World about 3 years ago with a finder gauge, haven't missed a TV signal yet. Well, if the weather allows it, its really not bad at all. I take one of my receivers with me on the road and use it for longer stays. Once you set it up a couple of times it becomes easier and easier. As I recall the dish was about $179 and the finder was about $29. Good luck which ever way you decide.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Easiest, most efficient way to skirt the tin can?? movin-in Winter Living 11 04-02-2012 10:49 AM
Easiest Route Across the Rockies boutdoors On The Road... 23 01-26-2011 10:45 PM
best (easiest!) '77 Bowen water heater replacement? JohnGalt48 Water Heaters, Filters & Pumps 5 09-28-2009 03:11 PM
1978 Argosy 28' - easiest way to access shower plumbing? argosy28 Argosy Motorhomes 0 08-25-2008 03:42 PM
Easiest way to flush black tank? JLD Waste Systems, Tanks & Totes 10 02-19-2003 07:16 PM
