Old 06-15-2014, 04:06 PM   #1
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Bedroom TV
We watched our first DVD on the bedroom TV last night. It took a while to figure out how to get the sound through the stereo system, until I realized the front TV has to be on for the sound to come through the stereo. It seems there ought to be a better way to wire it so you don't need both TVs going. Or am I missing something here?
2012 Dodge Durango Hemi/AWD
Old 06-15-2014, 04:32 PM   #2
rodsterinfl's Avatar
2006 25' Safari
Fort Myers , Florida
Images: 8
When you say that the front TV has to be on to have sound, does the front TV have to be showing the DVD movie for the rear one to show a picture? Does the DVD player shut off when the front TV is off or switched off?
The reason I ask is because I renovated my system and installed two TVs, wired HDMI and put a theater sound system in with blue ray, etc. My bedroom TV would not play sound but I would see the picture IF the front TV was also on too. If I turned off the front TV everything would shut off. I found the problem was DLNA. I turned off DLNA control on the player and TVs and everything worked perfectly after that. It is a setting in your menus on those devices.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 06-15-2014, 05:05 PM   #3
Wayne&Sam's Avatar
Images: 21
Thanks, I'll check that out.
The picture would show on the bedroom TV if the front TV was off (and I get sound from the TV speakers), it's just getting the sound to play through the Sony stereo that's the issue.
Old 06-15-2014, 07:05 PM   #4
2006 25' Safari
Images: 8
Ok, very different then.
Old 06-15-2014, 08:55 PM   #5
mefly2's Avatar
2015 25' FB Eddie Bauer
You are correct; we haven't found another way to get the big stereo sound either...the main TV has modified outputs that feed the other TV.
Leak at rear bedroom wall Kirby Stone Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 02-12-2010 12:41 PM
Early rear bedroom motorhome?? Curtis-79MH Our Community 14 12-23-2002 10:01 AM
Early rear bedroom motorhome Curtis-79MH Airstream Motorhome Forums 1 12-16-2002 05:26 PM
New bedroom cabinet 85 Sovereign j54mark Cabinets, Counter Tops & Furnishings 0 11-24-2002 07:36 PM
Tiny fan to bedroom of Sovereign helps cool and warm the space Joan D'Andrea Cabinets, Counter Tops & Furnishings 2 11-02-2002 12:10 PM
