Old 06-14-2007, 10:18 AM   #1
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Batwing Antenna Stand-Off
I'm not sure what TV antenna was on my AS first, but it has a standard batwing now. The problem is that when retracted, one element of the batwing lays on the center roof vent of the trailer. It is deforming the roof vent. Has anyone mounted a stand off on the roof for the antenna to lay in? I hate to have the antenna up off the roof when traveling, but don't want a leaking beat-up roof vent either.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 06-14-2007, 12:51 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If the bat wing is installed properly, it will fold down slightly at an angle to the axis of the trailer and fold flat against the roof. either the antenna was not properly installed or you are not getting the antenna into the right orientation before you lower it. I do not think your unit originally came equipped with a bat wing. It was likely installed by a previous owner.
Old 06-15-2007, 02:05 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Antenna standoff
This is what the PO of my trailer had done as far as a standoff. If I were to do it, I would not make it as tall as this one is and I would not put "ears" on the outside. When the antenna head was down, the aluminum wing on the AC side rested on one of the ears. It eventually cracked through one side of the aluminum wing and a crack was half way through the other. The standoff looks like a piece of aluminum bar bent so that the ears would keep the antenna arm reasonably centered or from swinging one side to the other. I would eliminate the ears and bend a small V in the center with rubber support of some type. I used a clear rubber bumper affixed to the antenna arm but you could use some type of rubber with screw to mount it on the arm. You could also use a piece of rubber in the V of the mount. Hope this helps.
ID:	39290   Click image for larger version
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 06-15-2007, 02:10 PM   #4
Central , Mississippi
My antenna - "The Monument To The Flying Nun" as we call it, angels slightly road side and clears everything
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
Which Antenna ?? Jim Clark Audio, Video & TV 1 07-21-2002 06:32 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
