Old 01-07-2010, 11:22 AM   #1
richinny's Avatar
2011 34' Classic
batwing antenna 15/16" nut socket won't fit through inside skin
does anybody have an easy solution to tightening this nut? the hole in the aluminum ceiling is too small for a standard 1/2" drive chrome socket. i'd like to avoid getting shavings inside the trailer if i grind the hole larger. is there such a thing as a thinwall socket in that size?
Ricky
Old 01-07-2010, 12:08 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I have one of these in my set: http://www.sears.com/shc/s/p_10153_1...&sName=Sockets. It's about as thinwall as you're going to get. It is pretty thin, if you have any kind of clearance at all, it should work for you. There is also a deep socket version, but all my deep sockets are impact sockets.
All the large bolts on the engines I rebuilt (Minneapolis-Moline) were 15/16, so I know that size pretty well.
Vaughan
Old 01-07-2010, 04:20 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
If you decide to enlarge the hole you could have a helper hold a vacuum cleaner hose up there as you work and you probably would catch the bulk of the cuttings
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-07-2010, 04:30 PM   #4
richinny's Avatar
2011 34' Classic
thanks for the replies. that is the socket i was trying to use, lol. i even tried a shower valve socket but that is thinner but not thin enough. a neighbor suggested peening the edge with a body work type spoon to open it up. i'll see how that goes tomorrow. i might try to find an 1.25" hole saw. i can pre-drill a scrap of wood to keep it centered.
Ricky
Old 01-07-2010, 04:49 PM   #5
Cantrell's Avatar
1985 34' Limited
1960 24' Tradewind
Summerville , South Carolina
Ricky,
My father dealt with the same issue a short time ago on his Winegard. He had a 31/32 basin wrench which fit in the opening perfectly. Basin wrench is used on old style sinks to get at the faucet nuts from beneath--it has a very slender profile. Maybe a rental place has one or if you have a plumber buddy you could borrow one from him.
Good luck.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 01-07-2010, 06:53 PM   #6
richinny's Avatar
2011 34' Classic
i had looked at that a the tool store. i didn't think it would fit. i think i can borrow one and give it a try. i'll let everyone know what the end result is.
Ricky
Old 01-15-2010, 08:09 AM   #7
richinny's Avatar
2011 34' Classic
my resolution was to peel the edge of the hole with a pipe and hammer. a gentle tap was all that was needed to peen the edge.i tried to thread the nut by hand and even that was too tight to verify that the nut was not cross threaded. I used a shower valve socket to tighten the nut because the standard depth socket would not reach the nut. a deep socket might have worked.
when all assembled, the mast would only lower part way, then would bind. a little lubricant made it work like silk.
Ricky
spindle nut socket size eugnicfrlie Axles 4 04-20-2009 09:12 AM
Batwing Antenna Stand-Off jdalrymple Audio, Video & TV 3 06-15-2007 02:10 PM
Where do I get a lug nut socket Antique Pedaler Wheels, Hubs & Bearings 3 11-27-2006 05:59 PM
Lug Nut Socket Help... AZstreamin Wheels, Hubs & Bearings 20 09-21-2006 06:04 AM
batwing antenna for 68 GT mimibeth Audio, Video & TV 0 07-22-2006 12:58 PM
