Old 06-23-2008, 08:35 PM   #1
1999 28' Excella
Fayetteville , Tennessee
Bad Cable from Power Amp to Winegard Roof Antenna
After considerable trouble in finding a bad cable from power amp to antenna causing bad signal to TV in just acquired 1999 Excella, now searching for information on best way to replace this cable. Any suggestions or advise will be appreciated.
tntom is offline   Reply With Quote
Old 06-24-2008, 08:09 AM   #2
Ned
1986 31' Sovereign
North Judson , Indiana
I would suggest an electrical installers trick of using the old wire to pull in the new. Disconnect the old at both ends. intertwine one end with the old and new. Pull on the other end until the new has a tether long enough to terminate.
hned10060 is offline   Reply With Quote
Old 06-24-2008, 08:44 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Before you remove the cable remove the antenna and check the condition of the cable end. Mine failed at the connector because the copper center wire just corroded off. Hopefully you will be able to get enough cable free to connect a new end.
It is highly unlikely that the cable itself has failed.
2004 Excursion 4x4
Old 06-24-2008, 08:09 PM   #4
1999 28' Excella
Antenna Cable
The trick of using old to pull new cable through just won't work on the Airstream. Cannot budge from either end and have I tried. Also cutting off connector ends have been done and no luck. Outter shield is okay but inner copper wire is open. Having spent the day trying with no luck, now looking for a way to route another cable to back of refrigerator and up to room and across. Don't like it but all I can come up with. Thanks for your suggestions and any other thoughts. let me know. Tom
antenna cable, tv cable, repair, winegard
Shore power cable - fixed or removable? malconium Electrical - Systems, Generators, Batteries & Solar 7 04-30-2008 04:45 PM
Fresh water enters power cable door on LY MH Santart Land Yacht/Legacy Motorhomes 14 02-14-2008 05:32 AM
Which Winegard Antenna? tlavergne Audio, Video & TV 20 08-26-2007 04:09 PM
Need help with a TV antenna cable... replacement Northway@mag Audio, Video & TV 7 07-16-2007 06:23 PM
Roof antenna on '77 LI Pets Audio, Video & TV 7 09-20-2006 10:08 AM
