Old 09-06-2012, 07:05 PM   #1
Geofreak
geofrk's Avatar
2007 27' Classic FB
Montgomery , Texas
Send a message via AIM to geofrk
Backup camera
I have an NPI wireless backup camera which is not working very well. Can someone recommend a really good backup camera and monitor system? --thanks...Art
geofrk is offline   Reply With Quote
Old 09-06-2012, 07:48 PM   #2
dznf0g's Avatar
Oswego , Illinois
Here's my saga on developing my analog system:
http://www.airforums.com/forums/f450...ras-83497.html
In the end, if money is no object, the only digital system I know of is Voyager, for twice the price.
-Rich-
Old 09-28-2012, 09:33 AM   #3
1990 34' Excella
Sugar Land , Texas
Exclamation Rear View Wireless Camera Systems
The reason Voyager wireless works so well is that it uses frequency hopping spread spectrum technology. The transmitting camera and the receiving monitor are digitally "paired" like you would with a Bluetooth device. Much better than units that merely transmit on one of four pre-assigned static frequencies selected with manual switches located on the transmitter and receiver. These much cheaper systems will pick up a lot of interference from various sources in neighborhoods, cities, and, to a lesser extent, even the Interstate. Competition will bring the FHSS technology to units that are somewhat less expensive than Voyager. Probably before the end of 2012.
MarkMc is offline   Reply With Quote
Old 09-28-2012, 10:11 AM   #4
dznf0g's Avatar
Oswego , Illinois
True, Mark. All that is covered in my link above. And translated to real world post install observations.
-Rich-
Old 09-28-2012, 10:15 AM   #5
1990 34' Excella
Sugar Land , Texas
Great! I can't wait to read the stories. This is the perfect way for us to learn from each other.
Old 09-28-2012, 11:20 AM   #6
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
Is there a bluetooth camera I can pair up to a ipod touch?
I'm only looking at the hitching up, for its use.
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 09-28-2012, 12:05 PM   #7
dznf0g's Avatar
Oswego , Illinois
Look for an app for that. Bluetooth is 2.44 Mhz, just like the monitor and camera that I used. If there's an app, I think you could use any analog 2.44Mhz camera. Range??????? No clue.
-Rich-
Old 09-28-2012, 12:30 PM   #8
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Greetings! Hey there dznf0g. I am right there with you. My story is somewhat different and my one system that I purchased, trying to save money failed on my first trip. So, I went back to the drawing board. Now, out $200 I started over. This time with a Voyager digital wireless system. I purchased the add on system hoping to use my LCD monitor but found that it would not work with it and ended up buying another monitor! $$$ later I have a working system with an excellent picture. The voyager digital wireless system works well on an Airstream. I would recommend it. I had so much trouble with the 2.4 ghz analog wireless cutting in and out. It was messed up by Bluetooth, wireless phones, cell phones with bluetooth, etc. awful. The problem is that with a system bothered by so many signals, there is no guarantee that it will work when you need it. So, that means that the choice is a wired system or a digitally locked system. The Voyager system is not cheap but it works.
Old 10-08-2012, 10:48 PM   #9
1990 34' Excella
Sugar Land , Texas
On the digitally locked system did you place the transmitting camera and antenna near the center marker light in the rear? Or did you position where you are transmitting through the rear glass toward the tow vehicle to avoid aluminum?
Old 10-09-2012, 06:26 AM   #10
dznf0g's Avatar
Oswego , Illinois
I gott tell you, with the polorized antennas, the interference is not too bad, except when MY phone is actively pairing and when I am on a call. I have little interference otherwise. When I am in a very populated area, I do get some jumping around, but it is very useable as a rear view mirror. And that's with a 30'er. It would be even better with a shorter AS.
-Rich-
Old 10-10-2012, 07:46 AM   #11
1990 34' Excella
Sugar Land , Texas
That's good to know. Thanks for the feedback and advice!
Old 10-12-2012, 10:14 PM   #12
2006 25' Safari
Images: 8
Digital Backup Replacement
Finally, here is a photo and an answer to your question via pics:
I drilled a hole and used a rubber grommet to seal the hole around the cable used for power.
Name:	light power.JPG
Old 10-12-2012, 10:35 PM   #13
2006 25' Safari
Images: 8
Mounting the camera
I mounted a voyager digital wireless camera just below the light used for power.
Old 10-12-2012, 10:36 PM   #14
2006 25' Safari
Images: 8
Another shot:
