Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 04-10-2010, 11:49 AM   #1
2012 25' FB Eddie Bauer
2009 19' International
Aptos , California
Audio whine when water heater is on
I've got a 2009 International that came installed with a Sony MEX DV2000 a/v system. There is an annoying high pitched whine that occurs intermittently. I believe I have isolated the appearance of the whine to the use of the water heater.
Does anyone have any ideas what could be going on here? I'm open to suggestions for additional trouble shooting and or potential fixes. My guess that there is some grounding issue doesn't get me far.
BTW, I'm currently ensconced at Dance Country RV Park in McCloud, California, where the sky is overcast and threatening rain. We're planning to fish the Upper Sacramento River if we ever get done with breakfast and lounging around. Quality note about the park: very nice spot, and well kept, but I wish the showers had a little more pressure.
brad1 is offline   Reply With Quote
Old 04-10-2010, 12:50 PM   #2
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
Any electronic circuit board can create radio frequency interference, you might experiment with using a ferrite suppressor on the 12v wire to the water heater circuit board, one of those little things that you often see on electronic cables.
Try a google search for "RF interference" or "ferrite suppressor"
snake is offline   Reply With Quote
Old 04-11-2010, 11:06 AM   #3
Aptos , California
Thanks snake. That makes sense and doesn't sound either too difficult or too hard to back out of if it doesn't work. I'll give it a try.
B
Old 04-11-2010, 11:23 AM   #4
Maniacal Engineer
barts's Avatar
Lopez Island , Washington
Does the whine occur only when using the radio? Or when using both radio and CD player functions?
In addition to ferrite beads, small tantalum (e.g. fast ) capacitors going immediately to ground from the power
input wire on both the Sony and water heater will help.
These will bypass high frequencies to ground; the ferrite beads block them as well and the effect is cumulative.
I'm surprised that the Sony is susceptible to this; a car is a very noisy place wrt RF, with alternators, small DC motors (windshield wipers, power seats/windows), etc. This is a common problem, and there are lots of hits on google for
"car audio noise filter" and the like. Any place selling better car audio gear will have stuff for this if you don't want to roll your own.
Lots to read... out there.
- Bart
Bart Smaalders
Lopez Island, WA
https://tinpickle.blogspot.com
barts is offline   Reply With Quote
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
high-pitched whine in speakers hjlincoln 2006 - 2010 International 2 06-08-2008 06:32 PM
Water heater & fresh water capacity ESCAPE POD Water Heaters, Filters & Pumps 5 11-14-2007 04:14 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
